Surging idle!! help
when I cold start the car in the morning, the idle surges from 1100 to about 1500. Kinda like when you have a vacuum line leak or air bubbles in the coolant. But the weird thing is that it just does it a couple of times and then goes back to normal and is completely normal after that.
I've checked all the vacuum hoses and can't figure out what can be causing this.
https://honda-tech.com/forums/honda-prelude-4/end-all-idle-surge-bounce-etc-problems-thread-1979500/
My lude does this as well, and I know it doesn't need an oil change and there are no leaks. It does it only when it's cold, as if it's trying to warm itself up...
ok, I have not fixed it yet but I think I might know what caused it. I cleaned out my IACV valve a month ago and of course the coolant leaked out from it. I think that it got some air bubbles in the coolant lines because of that.
I will bleed my coolant this weekend and report back. Hopefully, this was the cause. What is weird though is that this only started happening about a month after the IACV cleaning.
c for sea
22
Sep 19, 2006 11:02 PM
nekoabandoned
13
Feb 12, 2006 12:52 PM
