stroke an H23?
Old Apr 30, 2003 | 07:00 PM
mhgleitz's Avatar
Default stroke an H23?
i can't find a stroke kit for my H23. i've heard they exist but no luck finding one.
Old May 2, 2003 | 05:50 AM
mhgleitz's Avatar
Default Re: stroke an H23? (mhgleitz)
surely someone out there has stroked the H23.
Old May 2, 2003 | 06:09 AM
BoostedH23a1's Avatar
nope... hardly anyone makes **** for h23 much less a stoker kit. heard top fuel did but i dont think so.. never seen it
Old May 2, 2003 | 10:38 AM
mhgleitz's Avatar
Default Re: stroke an H23? (BoostedH23a1)
someone wrote the other day on here that they stroked their H23 to a 2.6. i don't remember who it was, but i'd like to here where they got their stroke kit, or if they were just making up stories
Old May 2, 2003 | 11:00 AM
93ludeSi's Avatar
I haven't heard of anyone making a kit, there isn't a lot of room to play with in that block
Old May 2, 2003 | 12:20 PM
2point6's Avatar
Default Re: (93ludeSi)
HEHEHE! I might know something about it... It will depend on the intention of your car. What I mean is relability for daily driving will be affected if you go to a 2.5+ ltr. My advice is to bore out the engine for the extra displacement. If you do intend to get more stroke out of this, you can weld the h23 crank, but it is not as strong as an h22a crank. I suggest when welding the crank, start with the strongest availible such as an h22a crank. Marine Crankshaft California does KILLER work. You can safely stroke this crank (for street use) from 90.7mm to 98mm. this combined with a 89mm bore will give you my current displacement of 2.44ltrs. This is not a cheap thing to do however, so keep that in mind. Also, if you are looking for reliability, don't bore out the block to 90mm as head gasket failure is all too common.
Check out my site for more info: http://www.collectiveracing.net
carpocas
Mar 25, 2021 06:44 AM
sikciv666
Mar 21, 2006 07:33 PM
noble4ws
Sep 25, 2003 08:15 PM
