Starting Problem: starter turns even without key
when i started my car today...it started fine but the starter continued turning even while the car was already on.
i quickly turned the key to turn it off and took the key out...
the motor cut out but the starter still continued spinning!
so i rushed to open the hood to disconnect the battery (no tools) and luckily the positive terminal was not very tight.
my car is able to start without pressing in the clutch because i jumped the clutch switch
but what could be the problem?
im thinking the main relay is stuck to the ON position or the ignition switch is stuck to the ON position too.
i also resoldered the main relay many months ago to fix it
i think it is the solenoid
but whacking it didnt budge it
i unplugged the ignition wires and even the main relay...but the starter will still turn when i plug the battery
i even put back the clutch switch and same thing
i might end up getting a new starter tomorrow
bad solenoid it was
the shaft stayed protruded even without power
whats crazy is....if my car was in gear and i plugged the battery...i wouldve gotten run overed
got a new/reman unit from NAPA for about 150
Black R
Apr 8, 2023 07:14 AM
91tegrals
Feb 12, 2012 09:03 PM
