start up question
Old Jul 12, 2004 | 07:23 AM
staticrex's Avatar
Default start up question
Would a motor ping on start up? Doesn't the motor have to be hot for the pinging to begin? If this is happening would my timing be too far advanced?
Old Jul 12, 2004 | 08:21 AM
staticrex's Avatar
Default Re: start up question (staticrex)
ahhh c'mon
Old Jul 12, 2004 | 08:33 AM
prelittlelude's Avatar
your motor isn't pinging,
yes it could happen on startup but i really doubt it,
did you change your timming at all from where keith had it?
Old Jul 12, 2004 | 08:37 AM
Sephro's Avatar
It could... Doesn't have to be hot. Timing too far off could cause it.
Unless you are meaning knock?
Old Jul 12, 2004 | 09:03 AM
staticrex's Avatar
Default Re: start up question (Sephro)
Well when I had the distributor replaced and valves adjusted I would assume the would adjust timing. So I am thinking maybe Keith had it at a certain degree, and then when it got put back together it was set different. It doesn't sound like knocking it sounds like pinging.
Old Jul 12, 2004 | 10:55 AM
staticrex's Avatar
anybody.
Old Jul 12, 2004 | 02:50 PM
Sephro's Avatar
Are you sure that the valve adjustment was done properly?
Old Jul 12, 2004 | 04:00 PM
staticrex's Avatar
I would assume Honda mechanics know how to do them, I took it to them. I even talked to the guy that did it and he said he did it to specs, seemed like a cool guy, not working to screw anyone over. So yeah I would assume that it was done correctly.
Old Jul 12, 2004 | 08:56 PM
staticrex's Avatar
I noticed today after all my gas was gone, I am getting worse gas mileage. Would that be a cause of incorrect timing?
Old Jul 13, 2004 | 05:03 AM
Sephro's Avatar
could. Just check your timing. Doesn't take long.
Old Jul 13, 2004 | 08:11 AM
staticrex's Avatar
Thanks I appreciate the help. Should it be set around 17 or below?
yo bj
Feb 2, 2011 05:54 PM
EFhatch2403
Apr 29, 2010 01:36 PM
Outlaw-Hondaz
Aug 26, 2009 12:21 PM
HSPxCARDO
Oct 23, 2007 10:10 AM
IAWIaccord
Oct 10, 2006 01:36 PM
