Stalling!!
Old Dec 6, 2004 | 01:45 PM
H22A1TLUDE's Avatar
Default Stalling!!
i have a 93 Vtec prelude with 142,000 miles. it stalls everytime i push in the clutch and come to a stop! when i push in the clutch the rpms go straight to zero(sometimes the car tries to stay running). its been doing this for a while on and off. it'll be fine for about a month but then it'll start stalling again. i live in florida where its really hot. it seems that my car stalls because of the hot weather. but SOMETIMES its fine when its hot out! when its cold its fine especially at night. my car's not overheating or anything. i don't get it, its so frustrating!! it does the same EXACT thing Eleanor does in Gone in 60 seconds, where the car is dying and its starts shaking making a funny idle then dies. what could it be!!! has anyone experienced this before. i hope this makes sense to all the readers cause i explained it the best as can.
Old Dec 6, 2004 | 02:17 PM
eric416's Avatar
Default Re: Stalling!! (H22A1TLUDE)
i got the same problem, no idea wat it is though. any help?
Old Dec 6, 2004 | 02:55 PM
Prolink's Avatar
Does it happen when it is only in gear? How does the car idle when in neutral?
Old Dec 6, 2004 | 03:17 PM
jackstands's Avatar
Default Re: Stalling!! (Prolink)
I had a similar problem. Is it harder to start when it's hot? Does it idle normally? Will it start while rolling if you dump the clutch? Check your main relay, IAC Valve as well as your igniter.
Old Dec 6, 2004 | 03:58 PM
H22A1TLUDE's Avatar
Default Re: Stalling!! (jackstands)
it happens in neutral and in gear. the car idles a little rough on neutral also. its harder to start when its hot too. i'll look into it more and let you guys know, but if you guys know anything let me know....thanks.
Old Dec 6, 2004 | 04:47 PM
BDAZSVT's Avatar
I have a 92 that is doing this also? mine starts fine though?
Old Dec 6, 2004 | 05:30 PM
H22A1TLUDE's Avatar
Default Re: Stalling!! (BDAZSVT)
can't wait to find out. its really starting to get annoying. i wonder what it could be cause it seems common.
Old Dec 7, 2004 | 04:42 PM
BDAZSVT's Avatar
I gave up already and dropped mine off at the shop tonight
Old Dec 7, 2004 | 05:56 PM
eric416's Avatar
let us know what they did when u get it back
Old Dec 7, 2004 | 06:00 PM
hOndafienD 04's Avatar
Default Re: Stalling!! (eric416)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric416 &raquo;</TD></TR><TR><TD CLASS="quote">let us know what they did when u get it back
Old Dec 7, 2004 | 06:38 PM
Honda318dx's Avatar
Default Re: Stalling!! (hOndafienD 04)
EGR problem. My brothers car just went though this because we had the vacume lines crossed
Old Dec 7, 2004 | 09:05 PM
PrettyLude's Avatar
check the main relay also
Old Dec 8, 2004 | 06:24 AM
Shakes's Avatar
space cadet
Default Re: Stalling!! (Honda318dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">EGR problem. My brothers car just went though this because we had the vacume lines crossed</TD></TR></TABLE>
i know mine is vacuum related. i have the exact same problem.
as rick mentioned to me, Vacuum problems are heat dependent. thats why when its colder out you are idling higher etc.
i blame mine on the duct tape, but it could very well be a cloged EGR... clogged by the DUCT tape....
Old Dec 8, 2004 | 06:25 AM
Shakes's Avatar
space cadet
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">check the main relay also</TD></TR></TABLE>
why would the main relay do this? if it were a relay it wouldnt care about the temp of the engine.
Old Dec 8, 2004 | 06:31 AM
Sticky Tires's Avatar
* B A N N E D *
No, check the hub caps. I guarantee that's the problem.
Old Dec 8, 2004 | 06:32 AM
PrettyLude's Avatar
he said that it would be harder to start when it gets hot
Old Dec 8, 2004 | 06:34 AM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">he said that it would be harder to start when it gets hot</TD></TR></TABLE>
heat raises, vacuum problem gets worse. with an improper vacuum the car will not want to start.
if we were talking carb'd engines then it wouldnt be a vacuum problem, but then again it still wouldnt be a main relay problem either
Old Dec 8, 2004 | 06:38 AM
* B A N N E D *
Default Re: (Shakes)
You're both wrong. It's the lug nuts, it's torqued too tight causing stress to the shafts/transmission.
The engine has to work harder, therefore the car stalls.
Old Dec 8, 2004 | 06:39 AM
Shakes's Avatar
space cadet
Default Re: (STicky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STicky Tires &raquo;</TD></TR><TR><TD CLASS="quote">You're both wrong. It's the lug nuts, it's torqued too tight causing stress to the shafts/transmission.
The engine has to work harder, therefore the car stalls. </TD></TR></TABLE>
lay off the avatar
Old Dec 8, 2004 | 06:40 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">
lay off the avatar </TD></TR></TABLE>
my backyard mechanic told me so!
*loads up P229*
Old Dec 8, 2004 | 06:42 AM
Shakes's Avatar
space cadet
*loads up P229* </TD></TR></TABLE>
grabs 226
Old Dec 8, 2004 | 03:27 PM
BDAZSVT's Avatar
He cleaned all of the sensors etc but said that yhe "Boost idle valve" or something like that was sticking. sorry I cant give the exaxct answer but he did fix it.
Old Dec 8, 2004 | 08:03 PM
el3vate's Avatar
My 92 Lude is doing similar idle problem. It doesn't do it every time I clutch, but if my car has been sitting for a while then I drive, I will stall until my car warms up. What is a good/normal idle? I'm idling at like 700ish.. Unfortunately it sometimes drops lower then that, and is pissing me off. Usually at night my car will feel its strongest.
Old Dec 9, 2004 | 02:59 PM
sr20dettrex's Avatar
ahh same prob..93 si vtec..
when i start the car (in cold weather)
- idles rough/high from like 2.25-2.75 rpms
- after it dies down of course, when ive been drivin for a bit..if i clutch to stop (in gear or not) it drops a lot of times to 0 and stalls
neutral it idles at about 700 too maybe even 500 sometimes..and fluctuates from 500-250. if i step on the clutch, it drops lower almost every time.. so its basically i have trouble in the cold..dont rem havin this problem like 2 months ago in warm weather.
Old Dec 15, 2004 | 03:28 PM
H22A1TLUDE's Avatar
Default Re: (sr20dettrex)
I finally took my car to a mechanic today and got it fixed!!!! Dropped her off, went home and waited for them to call. I couldn't wait to find out what the problem was. anyways, the mechanic called and told me that my car was ready!! my mechanic told me it was nothing major. All he did was ADJUSTED and CLEANED the IDLE AIR SYSTEM. everything was fine after that!!! it feels so much better that i don't have to worry about stalling at every stop anymore!! i hope everyone with this same problem can get it fixed also. Good Luck!
