SRS System
Old Jan 21, 2003 | 10:11 AM
elnoyl's Avatar
Default SRS System
Hi i have a 95vtec. The airbags have been deployed. The srs light is currently on. I'm wondering what is involved in getting the airbags back to original state. I have already bought the airbags and srs modulator. Do i just plug the bags and the modulator back in? If i plug them in is the light going to go off and the system function properly. What other steps would i have to do?
I'm looking for these parts:
carpet (dark)
Sunvisors (gray and must be from 94-96)
Headliner (gray and must be from 94-96 vtec)
Domelight with maplights (black o gray and must be from 94-96 vtec)
Front seats bolt covers (black)
Old Mar 4, 2003 | 06:34 PM
LordVtec's Avatar
Default Re: SRS System (elnoyl)
1) Ignition OFF
2) Connect a jumper wire to the the "Memory Erase Signal" (MES) connector (2pin). This two pin connector is either Grey wires or Green. Mine was a green connector I think and NOT yellow. There should only be two 2P connector to be found up under the driver's side dash to the driver's side of the steering column. I used a paper clip with a electrical tape to make an insulated holder with two pin sticking out.
3) Turn the Ignition ON
4) SRS light comes on for about 6 SECONDSand goes off. Remove the jumper within 4 SECONDS after the SRS light goes OFF.
5) The SRS light comes on again. Jumper the connector again within 4 SECONDS.
6) The SRS light goes OFF. Remove the jumper within 4 SECONDS. (Yes that's another 4secs )
7) You will know at this point if you got it right when the SRS light blinks twice (memory erased)
8) Turn the ignition OFF, and wait 10 SECONDS.
If this doesnt work, i would suggest taking it in to the dealer and have them give it a shot... hope this helps
Jeremy Gobble
Honda CR-V & Element
May 23, 2019 02:12 PM
dem0nk1d
32
Sep 29, 2011 02:58 PM
revlimitx04
Mar 13, 2011 10:28 PM
EK_B
Dec 23, 2008 03:08 PM
eluam
Jun 20, 2007 06:14 PM
