squealing noise
Old Oct 13, 2004 | 12:48 AM
AznBlueBoy's Avatar
Default squealing noise
ok i read its probably the power steering belt and you just got to tighten up the belt
can anyone explain how you do that?
sorry im not too good with this stuff.
Old Oct 13, 2004 | 03:19 AM
mugen88crx's Avatar
Default Re: squealing noise (AznBlueBoy)
on the back side of your power steering pump, there is a long bolt that goes from the pump to a bracket below, simply tighten that bolt to tighten the belt... you may want to loosen all the bolts holding on the pump first (itll make tightening the belt easier). if this doesnt stop the squeking you may just need a new pump. i just put in a new one last week!
Old Oct 13, 2004 | 02:33 PM
AznBlueBoy's Avatar
Default Re: squealing noise (mugen88crx)
well i tightened the bolt but still the things still sqeauling.....><
Old Oct 13, 2004 | 04:22 PM
copmagnet's Avatar
you might need a new belt cuz the squeal qhen u need a new one sometimes
Old Oct 13, 2004 | 05:05 PM
britishlude's Avatar
Default Re: squealing noise (copmagnet)
Thats true they get a shiny glaze on when they have been slipping any length of time, and you have problems getting grip no matter how much you tighten up.
Old Oct 13, 2004 | 07:27 PM
AznBlueBoy's Avatar
Default Re: squealing noise (britishlude)
shiny glaze?
thats on the inside of the belt?
where the grooves are?
maybe its time to upgrade to some aem power pullies?
Old Oct 13, 2004 | 10:32 PM
AznBlueBoy's Avatar
also if i get the aem pulleys off a guy with a 5th gen, would i need different belts? or is it the same? i heard sometimes it doesn't come with the right belts...
Old Oct 14, 2004 | 12:33 PM
PrettyLude's Avatar
its different belts. i wouldn't recomment changing the pulleys out, i had it on my alternator, at idle the pulley was not cranking out enough current and it would my battery.
Old Oct 14, 2004 | 02:14 PM
AznBlueBoy's Avatar
Default Re: (PrettyLude)
maybe i need to get an optima too then
but anyways
why is it different belts?
we both have h22's but his is a 5th gen...wouldnt those belts fit on my car if i just buy it off him?
Old Oct 15, 2004 | 10:57 PM
PrettyLude's Avatar
you would have to give him the belts if you sold him the pulleys, because the aem pully has its own belts when you buy them, so normally the pully is bigger and u would need a bigger belt than the factory one
Old Oct 16, 2004 | 06:26 PM
AznBlueBoy's Avatar
yeah i know but hes giving me his belts that hes using with the aem pullies right now.
matmcg
Apr 18, 2008 07:57 PM
ZakkWylde
May 21, 2007 12:45 PM
J9D6M
Jul 13, 2006 06:28 AM
digitalh3lix
Dec 3, 2004 11:00 PM
sidewayz
14
Jun 5, 2002 11:48 AM
