Spedometer is not running
Old Oct 23, 2003 | 09:46 AM
Puki
Guest
Posts: n/a
Default Spedometer is not running
Ive searched everywhere for my Chilton Manual and I couldn't find it.
I recently took out my tranny and installed a new clutch. Tuesday I was in such a rush to put the car back together that I think I missed something, the Odometer,Spedometer!
If you can tell me where it is at or a diagram to show me where I can find the spedometer. I have a little metal pin about 1" inch in length, is this the pin needed for the spedometer.
Old Oct 23, 2003 | 09:55 AM
CHK4TIX's Avatar
Default Re: Spedometer is not running (Puki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Puki &raquo;</TD></TR><TR><TD CLASS="quote">Ive searched everywhere for my Chilton Manual and I couldn't find it.
If you can tell me where it is at or a diagram to show me where I can find the spedometer. I have a little metal pin about 1" inch in length, is this the pin needed for the spedometer.</TD></TR></TABLE>
the speed sensor (vss) is located directly below the intake manifold on the transmission, near the rear engine mount. It has two hoses connected to it and mounts with one bolt.
As far as the pin goes is it a cotter pin? if so it may go to the shift linkage but thats just a guess
*edit*
by the way chilton is worthless get a helms manual
Old Oct 23, 2003 | 10:15 AM
Puki
Guest
Posts: n/a
Thats what I disconnected when removing everything off the tranny. Hrmmmm Im going to remove the Intake and try to squeeze under the intake mani . I need to get my car smog checked. Thanks for help. Ill be back
Old Oct 23, 2003 | 11:09 AM
prelittlelude's Avatar
Default Re: (Puki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Puki &raquo;</TD></TR><TR><TD CLASS="quote"> Hrmmmm Im going to remove the Intake and try to squeeze under the intake mani . </TD></TR></TABLE>
don't mis read what he said, its under but not directly, i can reach mine just fine with just taking th the stock intake off, do not take the who intake mani off!! i mean yeah you will have alot of room them toi work with, but i can take my VSS in and out without taking my mani off, just the stock intake, he way just trying to tell you in the general area where it was
Old Oct 23, 2003 | 11:21 AM
Sephro's Avatar
Default Re: (prelittlelude)
It's just the plug in the top that needs to be plugged back in. Or pushed in a little more. The 2 tubes that come out of it go to the steering rack. That's where the speed sensitive steering.
romoracing
Audio / Security / Video
Sep 11, 2005 09:43 PM
LASSEN768
Aug 19, 2004 01:29 AM
mixmastabob
Aug 16, 2004 09:59 PM
b16_madman
Aug 9, 2004 05:18 PM
Slimm-rw-
Aug 9, 2004 01:29 PM
