Sooo... my...
Crankshaft pulley bolt, item # 20 snapped in half and the crankshaft pulley item #19 was chillin in my engine bay, luckily it didn't fall out... Obviously all the accessories belts came loose, my battery light turned on, lost power steering, and then the car wouldn't crank anymore... I recently did a timing belt job, torqued the crankshaft pulley to 110 lb, I do not know if that's the correct spec...
What is the effect of this??? Is my motor toast? Any tips, suggestions?
I have lost the bolt once, and had the bolt come loose but not gone once. Safe both times, just make sure everything is aligned right, and tighten it to proper torque, which is like 240 lbs.
Last time I lost the p/s belt on the road, and alt belt in the engine bay, so I fixed it at work and drove home. The time I lost the bolt all the way, both acc belts were on, but the crank pulley slid out enough to come off the key and the engine died, I was cruising at like 2500, so it was ok when re-timed.
Yea i was pulling in to the grocery store and was going around 5-10mph at most and I heard the clunk and battery light... well its time to work on it tonight.. ugh...
Thanks!
Thanks!
You can get some loctite on that bolt. If you get the bolt from honda you will see it already has some on the threads. I believe the loctite color on the stock bolt is red.
And make sure your crankshaft key didn't get damaged/chipped. if so it will make the crankshaft wobble and over time come loose again.
Also check the area on the crankshaft pulley around where the key sits, to make sure that it didn't get chipped.
GL
GL
Dont forget part # 15, just so you know. You can run about 6-800 miles without that part in there ;P I wasnt running the balance shaft belt and forgot to put it in there. My timing belt got eaten up but didnt snap.
HatchBlakKidd
May 30, 2011 07:14 PM
