someone help?
Old Apr 27, 2003 | 05:48 AM
crxludeT66's Avatar
Default someone help?
i have a 95 h22 a closed deck,we melted a je piston screwing around with the aem ecu.we were tunning under boost using a 2 bar map sensor map and i did'nt know i had the wrong map sensor which i did'nt find out until after i blew that piston,i had a 3 bar map sensor anyway to make a long story short the 3 bar screwed up the ignition and the fuel maps and added too much timing under boost.i work at a machine shop we normally work on big blocks and small blocks,should we do the same steps resleeving the block like we would do on a v8 or is there a speicial technique.i did a search here and i cant find anything,oh yeah the sleeve im using is the darton insert looks like a factory sleeve."poison do you have any sugestions or links".thanks danny
Old Apr 27, 2003 | 12:49 PM
crxludeT66's Avatar
Default Re: someone help? (crxludeT66)
someone has to know something ?
quickchris
Jul 28, 2006 09:47 AM
BoostedJeff
Sep 24, 2004 09:27 AM
1.8turbolsvtec
Apr 14, 2004 04:20 AM
philo
Dec 3, 2002 08:37 AM
gs-turbo
Mar 23, 2002 01:08 PM
