Smoke
Old Mar 16, 2002 | 03:15 PM
Islander9407's Avatar
New User
Default Smoke
Could someone tell me if my rings are gone or if my valve seals are leaking or if my turbo seals are gone? Whenever I rev my car blueish/whiteish smoke comes out the exhaust. I did a compression test and I got 167-170 across. My engine was rebuilt to 9.0:1 compression ratio(JG). My head was done to JG Pro Series specs. I've only put approximately 1500 miles on my car thus far. Is it possible if I'm running too rich that could cause this? Up to this day I'm still trying to tune my fuel system. Right now I'm trying to use the Hondata system with 550ccs.
Old Mar 16, 2002 | 03:42 PM
vpforeva's Avatar
New User
Default Re: Smoke (Islander9407)
for sure you're burning oil or/and coolant, u cant tell if its rings or valve seals or turbo seals unless you open it up and have a look
Old Mar 16, 2002 | 06:01 PM
New User
Default Re: Smoke (vpforeva)
What if I do a leak down test? Would that help in determining what's the cause?
Also, I checked my plugs and they show no signs of oil fouling. They are black from too much fuel, not oil.
[Modified by Islander9407, 3:14 AM 3/17/2002]
Old Mar 16, 2002 | 08:49 PM
vpforeva's Avatar
New User
yea leak down test would help
Old Mar 17, 2002 | 02:02 PM
laughinxxx's Avatar
New User
Blue smoke is coolant. You probably blew your head gasket.
Old Mar 17, 2002 | 02:11 PM
kevie88's Avatar
Default Re: Smoke (laughin2.2)
er, coolant smoke is white.. oil is blue.
Sounds like it's probably the head gasket, but my crystal ball is busted.. yer gonna have to take it apart!
[Modified by kevie88, 11:12 PM 3/17/2002]
Old Mar 17, 2002 | 07:57 PM
laughinxxx's Avatar
New User
Default Re: Smoke (kevie88)
That is correct. My fault. I guess it is all a matter of how blue the smoke was, when compared to white it was.
coltonbarrier
Aug 29, 2013 02:27 AM
drummr6
Jan 3, 2008 07:26 PM
luckypon7
Sep 4, 2003 05:36 AM
Witty
Jul 7, 2003 06:12 AM
Dodger2940
Aug 18, 2002 01:06 AM
