running lean
Old May 16, 2003 | 06:44 AM
Uman's Avatar
Default running lean
If I am running lean what are the steps I need to solve the problem. As far as I know this has never happened before. I came to this conclusion based on the appearance of the spark plugs and the readings of my g-tech. With ever run I am losing horsepower compared to the previous run. It seems as though the engine is running hotter than it should be causing a loss of power. Previously, I was able to make as many runs as I would like and come within 2-3 hp on ever run. Also, I have not switched intakes. The only thing I have done since this has happened is installed a suspension which involved unplugging a couple of wire harnesses above the front right shock.
Old May 16, 2003 | 06:49 AM
JG Luder's Avatar
Default Re: running lean (Uman)
if your plugs are white, then it's running lean.
I'd get an FPR and raise your fuel pressure. Another handy tool is an A/F gauge... get one, it's your friend...
Or you could just make sure you PLUGGED EVERYTHING BACK IN RIGHT.
Old May 16, 2003 | 06:51 AM
Uman's Avatar
yes, the plugs are white and I double checked the connections.
Old May 16, 2003 | 11:55 AM
LudeyKrus's Avatar
Default Re: running lean (Lone Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lone Luder &raquo;</TD></TR><TR><TD CLASS="quote">Another handy tool is an A/F gauge... get one, it's your friend...
I thought a/f gauges weren't any good unless you had a wideband O2 sensor?
BoldFart16
Jul 4, 2011 11:51 AM
sohctodohc
18
Oct 22, 2005 02:27 PM
tea
Sep 26, 2003 07:09 PM
J337_UNIT
Apr 13, 2003 04:29 PM
Nate B
Feb 10, 2003 08:26 PM
