Rough Idle
Old Feb 28, 2003 | 04:16 PM
jarero's Avatar
Default Rough Idle
I just bought a 92 Si 5 speed and it has a rough idle problem. If I rev it to about 1000 it smoothes out and rund perfect. Below that it's pretty bad. I have changed the plugs, checked the wires, changed cap and rotor. I need some suggestions on what to look for next. I would appreciate as much help as possible since this is my first Honda I have owned and want it to be a pleasant experience.
Thanks
Old Feb 28, 2003 | 04:20 PM
Que_Lude's Avatar
Default Re: Rough Idle (jarero)
Oil change?
Check to see if the person did a coolant bypass mod. (Gives a surging idle)
May need to adjust the idle screw on the TB to 700-750rpms or so.
If it has a lot of mile on it, you might need to clean the injectors. I had a bunch of carbon on mine when I placed a fuel rail on the other month.
Old Feb 28, 2003 | 04:49 PM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Rough Idle (Que_Lude)
vacuum hose?
Old Feb 28, 2003 | 08:32 PM
jarero's Avatar
Thanks for the suggestions. The oil was recently changed. I should also mention that this car is bone stock, however it does have 200k on it.
Thanks
Old Feb 28, 2003 | 08:57 PM
y0ungsta's Avatar
Have you tried cleaing the throttle body? I had rough idling on my 95 prelude due to unclean throttle body and after cleaning it with CRC intake throttle cleaner (don't get the carborator cleaner) it was much better.
Cardinals87
Sep 21, 2016 07:24 PM
mattkins91
23
Jul 6, 2009 08:06 PM
dth0ng69
Jun 28, 2008 08:04 PM
takeit
Sep 11, 2007 06:31 PM
jaycapz
Sep 2, 2004 11:32 AM
