Reset ABS warning light
Old Aug 17, 2005 | 08:01 PM
flashmang's Avatar
Default Reset ABS warning light
1993 honda prelude
Had tires balanced today and ABS light has been on ever since. Discount Tire told me that you have to reset the warning to get it to turn off. I find this odd that in the 5 years that i have owned the car, many rotations, balances and 3 sets of wheels that taking the wheel off has never tripped the ABS light untill today.
Anyways, if this is what is causing it ... what is the proper way to reset it????
Disconnection of the battery ????
Thanks Mucho !
Old Aug 18, 2005 | 12:37 AM
JOPINOYZ's Avatar
Default Re: Reset ABS warning light (flashmang)
I HAV THAT PROBLEM TOO. I INSTALL MY NEW SHOCKS, TURN ON THE CAR THE ABS LIGHTS ON. HOPEFULLY SOMEBODY CAN HELP US. :
alphabeatsco2004's Avatar
i want to know too!!!
how to reset the ABS codes.
Old Aug 18, 2005 | 07:02 AM
flashmang's Avatar
Default Re: Reset ABS warning light (alphabeatsco2004)
bueller bueller......bueller......
Old Aug 18, 2005 | 08:09 AM
BlackLudeSi's Avatar
there is no "reset" for the abs simply disconnect your battery for at least ten seconds, reconect and start car. If abs light comes on when you start your car and does not go off there is something wrong with the actual modulator/pumps. If the abs light goes on when you start driving it is a wheel speed sensor. Easy to check either way
Old Aug 18, 2005 | 09:07 AM
flashmang's Avatar
Default Re: Reset ABS warning light (BlackLudeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackLudeSi &raquo;</TD></TR><TR><TD CLASS="quote">there is no "reset" for the abs simply disconnect your battery for at least ten seconds, reconect and start car. If abs light comes on when you start your car and does not go off there is something wrong with the actual modulator/pumps. If the abs light goes on when you start driving it is a wheel speed sensor. Easy to check either way</TD></TR></TABLE>
you da man
gregd101
Honda CR-V & Element
May 29, 2011 03:11 PM
Nicks95GSR
Nov 25, 2006 07:26 PM
extracrunchie
Oct 19, 2004 08:21 AM
Scither69
Jun 9, 2004 09:19 PM
