Question before driving to DYNO
Before i began putting my turbo parts into my car, i was just wonderin if I should have the shop install it before they dyno it, or should i put the parts in myself? My concern is, if i put the high volume fuel pump into my car, install the new ECU, bigger injectors, and the turbo parts, will i still be able to drive my car to the DYNO? Would it be safe? What should i do?
the cheapest and safest option you have is to install the turbo parts yourself and tow/trailer it to the dyno shop.
Be sure to post up the setup and results. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax420 »</TD></TR><TR><TD CLASS="quote">the cheapest and safest option you have is to install the turbo parts yourself and tow/trailer it to the dyno shop.
I agree, tow it. No need to destroy the engine on the way to the dyno.
</TD></TR></TABLE>I agree, tow it. No need to destroy the engine on the way to the dyno.
i will be renting a trailer from u-haul. being i have to take it to another state. ive heard its pretty cheap. that is what i would recommend. all u need is a trailer hitch. and ur good. plus itll mean that much more when u drive it home.
have fun!
have fun!
