Question about suspension
Hey guys I just bought some front and rear sway bars. I want to build my suspension really good. I already got all the sturt bars and I have the Tanaebe Sustec Pro Coilover system. So my question relates to my sway bars. What are the linkage bars that hold the each end of the sway bars to the frame called? Lateral Linkage bar? And who makes some upgraded ones for the 5th gen preludes? Also how much am I looking to spend? Is there bushings that I can get for the sway bars. I just want to put all this together so I don't have to come back and take things out again to install new stuff. Please help! I need websites, prices, anything. Thanks alot guys!
I do not know what brand of bars you have. However, you are supposed to use the stock links with the Neuspeed bars. They are strong enough that Neuspeed's engineers do not believe it necessary for you to replace them. Both Neuspeed and Suspension Techniques include most everything else to make the install painless from a parts point of view
. There is a way to upgrade the links for a 5th gen, but it is not as cost effective as one might think. For your info-to take the stock links off you will need a 5mm allen key along with a suitable wrench. The stock part is similar to a ball joint and can rotate if you don't use the key (found out the hard way). To lube the bushings in the kit-use all of the supplied grease.Good luck and happy Luding
I do answer e-mail
Niskyspy
Feb 6, 2008 04:13 PM
hondacivic4g
Oct 31, 2002 05:14 PM
