Pulling the engine
Old Jul 17, 2003 | 05:06 AM
Sephro's Avatar
Default Pulling the engine
I know I should look before I post but I can't till I get home and then it would be too late to ask.
I am pulling my engine tonight(hopefully) to change my clutch/flywheel. I wanted to know how you connect the hoist to the engine. Is there a certain place.
Sorry if this is a n00b question but it will be the first time I have ever pulled an engine.
Oh yeah BTW H23
-Thanks!
Old Jul 17, 2003 | 05:16 AM
Prelude Vtec 23's Avatar
Default Re: Pulling the engine (Sephro)
This is the first time you are pulling the motor and you are about to change your clutch and flywheel? Well if you have a helms it will show you were to connect to lift the motor. If you dont have one you should get one first before you do this.
Old Jul 17, 2003 | 06:08 AM
Sephro's Avatar
Default Re: Pulling the engine (Prelude Vtec 23)
Okay, it is in the helms. I thoguht it might but figured I would ask now just to be safe.
Thanks
Old Jul 17, 2003 | 06:11 AM
Boostless97Lude
Guest
Posts: n/a
damn man, i've pulled mine so many times i can get everything unhooked, and the motor out in less than an hour now......
yeah, check the Helms
Old Jul 17, 2003 | 07:32 AM
Greyout's Avatar
Default Re: Pulling the engine (UN-Boosted97Lude)
Why are you pulling the engine out just to do a clutch & flywheel?
Old Jul 17, 2003 | 07:33 AM
Sephro's Avatar
Default Re: Pulling the engine (Greyout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">Why are you pulling the engine out just to do a clutch & flywheel?</TD></TR></TABLE>
I have heard that it is easier to get it back in. That and I want to do some other work while it is out.
Old Jul 17, 2003 | 07:42 AM
Greyout's Avatar
With the Transmission off, you'll have about 2 feet of working room.
But if you're going to do other stuff to it while its out then
Old Jul 17, 2003 | 08:28 AM
Elkins911's Avatar
drop the motor out the bottom of the car. you dont need a hoist.
Old Jul 17, 2003 | 09:22 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Pulling the engine (Elkins911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 &raquo;</TD></TR><TR><TD CLASS="quote">drop the motor out the bottom of the car. you dont need a hoist.</TD></TR></TABLE>i tried that once with my teg......... never done it since then either
Old Jul 17, 2003 | 01:09 PM
Behan's Avatar
yeah but you should have a lift, IMO if your in a shop and trying to get done fast its the way to go. But at home, in the garage, use the hoist.
Old Jul 17, 2003 | 02:05 PM
Greyout's Avatar
Default Re: Pulling the engine (93preludevtec)
Drop the engine out the bottom?? Then what? Take the wheels off and drop the car over the engine?
Old Jul 17, 2003 | 03:30 PM
DubbleD's Avatar
jus jack the front up kinda high, jackstands and drop the tranny down...u dont need that much room.
Old Jul 18, 2003 | 05:16 AM
CHK4TIX's Avatar
Default Re: Pulling the engine (DubbleD)
damn, i had a harder time just removing the tranny then i did removing the whole engine.
AnotherSi33
87
Dec 8, 2008 08:42 PM
chicken18
Jun 4, 2007 10:48 AM
CleanLikeJdm
Feb 11, 2005 05:36 PM
masters101
Nov 21, 2004 09:08 AM
