Prolems With ICM
Old Jul 27, 2009 | 09:03 AM
4thand5thgens's Avatar
New User
Icon3 Prolems With ICM
I have a 96' Prelude V-tec and my icm keeps going out. I brought it to a mechanic they replaced the icm and I've replaced it 2 times after that. Any suggestions on what could cause this? I checked the coil the secondary winding has 17.81k ohms, the primary winding shows 0.00 that doesnt seem right but I pulled the coil off my other lude and same thing is it possible that both coils are bad? I checked the coil wire thats fine, I have a new cap, rotor, Wires and plugs. I did continuity check everything seemed fine nothing is shorted to ground. Only thing I didnt check was the wire going to the tach but would that cause any problems??? I dont have a clue can someone help?
Old Jul 27, 2009 | 02:10 PM
THC07's Avatar
Default Re: Prolems With ICM
0.00 would burn out a ICM.
what kind of meter are you using?
it is possible that both coils are bad.
Old Jul 27, 2009 | 02:15 PM
New User
craftsman digital multimeter. So you think it would be worth it to go and get a coil and another icm??
Old Jul 28, 2009 | 09:15 AM
THC07's Avatar
I would get new ones. if one fixes the issue return the other.
Old Jul 28, 2009 | 09:51 AM
New User
I went and bought another coil and they all check out the same. i replaced the icm a 3rd time and it fires right up but itll end up burning out again and i still cant figure out what the prob is. Anyone have any ideas?
Old Aug 12, 2009 | 06:49 AM
Xquesiano's Avatar
[warned about signature]
Bump because i may be having this problem too. Its not a prelude though its a civic. I've replaced it twice, last time 3 months ago. I;m getting signs of a faulty ICM once again. If there is something wrong in my electrical/ignition system which is causing this, what could it be? I'm an idiot when it comes to electronics.
Old Aug 13, 2009 | 02:54 PM
MikeLuder's Avatar
both of you guys should just buy new distributors from distributor king. These things go out a lot i've also had 3 of them go out.
Need new dizzy
lewzor
Jan 25, 2017 05:10 PM
1992blueGSR
Oct 24, 2008 06:11 PM
jdmeg9
Sep 5, 2006 02:53 PM
thug252
14
Oct 24, 2004 04:58 PM
vteckilla7
Aug 8, 2004 01:41 PM
