Problems with ATTS
Old Mar 19, 2003 | 02:41 AM
PreludeXonxC5s's Avatar
Default Problems with ATTS
I was wondering how many of you have problems with ATTS in the 5th gen prelude. i just recently purchased a 2000 Prelude SH and people have been telling me that the ATTS light will turn on if i lower my car. WIth this, i was wondering, will i lose any performance in handling?
Also, i have searched about a topic on springs in this forum. And i have still questions. People in this forum said that i could use any springs as long as i change my shocks too, but will i lose in handling since the SH is built for handling?
Please be nice, Ive seen how harsh some of you can be
Thanks
Old Mar 19, 2003 | 03:13 AM
Shakes's Avatar
space cadet
Default Re: Problems with ATTS (PreludeXonxC5s)
good choice
if you dont want to loose handling - GC coilovers with koni yellow's seems to be the general consess, or if $$ is no matter, get TEIN or Showa (sp) which are found at http://www.kingmotorsports.com
we are only mean if you are stupid
Old Mar 19, 2003 | 03:16 AM
Default Re: Problems with ATTS (shakes)
Thanks shake for the post, but i was also wondering, people have been telling me the ATTS light will turn on if i lower my car and if the ATTS light turns on does this mean the ATTS is not working? If so how could i fix this problem...THanks
Old Mar 19, 2003 | 04:23 AM
DR's Avatar
DR
Don't worry about the ATTS; it will work fine if your car is lowered. People who say stuff about ATTS not working on lowered cars are misinformed. I have a lowered Type SH (GC/Koni) which I have autocrossed/DE/road raced for 5 years now and have had zero ATTS problems.
Old Mar 19, 2003 | 12:25 PM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Problems with ATTS (DR)
ATTS works fine when the car is dropped mildly. just don't slam it and drive it daily, it could cause the ATTS to fail. your handling will be better if the SH is dropped even on stock shocks w/ aftermarket springs, it'll just be bumpy/bouncy. just make sure all 4 coilovers are measured correctly on the front/rear and you won't have a problem. the ATTS sensors are sensitive, if it feels that the car's stance is mismatched it might set off the ATTS light.
Old Mar 19, 2003 | 02:29 PM
sslude's Avatar
Default Re: Problems with ATTS (Sticky Tires)
i would say go for TEIN, but the only problem is money.
Old Mar 19, 2003 | 03:03 PM
DsITR's Avatar
Default Re: Problems with ATTS (sslude)
The ATTS is more sensitive to the tire size you are running than the ride height.
I have ran my car on uneven heights..on accident of course . w/zero problems.
Old Mar 19, 2003 | 03:44 PM
* B A N N E D *
Default Re: Problems with ATTS (dsludefosho)
yeah tire size matters too. i remember the ATTS light coming on when i used my spare tire after a flat.
Old Mar 19, 2003 | 05:21 PM
piotrush's Avatar
Same here, but I think that was because the wheel speed sensors noticed the difference in rotation on the wheel with the spare. Do you think the ATTS would notice if all wheels were, say, 15 in. or 18in. ?
[Modified by piotrush, 3:22 AM 3/20/2003]
Old Mar 19, 2003 | 06:19 PM
Default Re: Problems with ATTS (piotrush)
Thanks guys for your response. You guys say that tire size matter, so putting on my old 18 iinch C5s from my accord would probably make the ATTS light turn on right?
[Modified by PreludeXonxC5s, 3:19 AM 3/20/2003]
Old Mar 19, 2003 | 09:58 PM
Ransom's Avatar
No, what they are saying is that if you run a different series tire in the back than in the front it will throw the light...I know from experience....Putting 18s on wont throw the light.
Old Mar 19, 2003 | 11:29 PM
krnboixshawn's Avatar
Default Re: Problems with ATTS (LudeSH)
lowering ur car will not turn on the atts light. i've had my 01 prelude lowered 1.8 inches and is working fine, but one day it just came on and stayed on. i have no reason why it did and neither does the dealer, but they just resetted the whole thing and now its working mine
Old Mar 20, 2003 | 12:33 PM
* B A N N E D *
Default Re: Problems with ATTS (krnboixshawn)
i run 18's on all four and no problem with ATTS. you can probably run stock 16's in the front and 18's on the rear, but i never tried it. just don't mismatch the sizes for the front/rear.
Old Mar 23, 2003 | 03:45 PM
DsITR's Avatar
yes..I have run 17's in rear and 16s in front w/no problems..
you cant have 17's on the RF and 16 on the LF...that would cause some problems.
As long as the same diameter tire is directly across from each other.
Rob97'SH
Suspension & Brakes
May 27, 2007 08:01 PM
capsule
Suspension & Brakes
Dec 24, 2006 11:44 AM
kadidle
Nov 8, 2006 05:40 PM
Phat8186
Feb 3, 2006 04:12 PM
mjH22
Jan 26, 2006 10:21 AM
