problem with ac and ???
Old Aug 13, 2001 | 11:06 PM
luder's Avatar
New User
Default problem with ac and ???
I have a 93 v-t with about 75k on it. I had a problem with my ac i refiled with freon but now i am geting water leek thru the ventilation houses on driver side and on passenger side too. Does anyone know how to fix this? I also noticed that when I turn ac on (the water that usually you can see under your car when you have ac on) I do not get that water any more. It is accumulating somewhere in my car. Can anyone help? Where should I look and how?
Old Aug 14, 2001 | 05:49 AM
Gabe's Avatar
Default Re: problem with ac and ??? (luder)
Sounds like you need the AC drain line blown out (it drains the water that condenses on the cooling coil on the inside of the car). Take it to the dealership and tell them what's happening. It'll take them about 10 minutes to blow the line out and they might not even charge you.
Gabe
Old Aug 14, 2001 | 09:29 AM
atomx's Avatar
New User
Default Re: problem with ac and ??? (Gabe)
GO VOLS!
methods555
Jul 22, 2007 08:26 AM
3rdgenLS
Aug 3, 2006 11:20 AM
crazyteg95
Oct 9, 2004 08:45 AM
Demon R
May 23, 2004 10:46 PM
