Preparing to Drag
Old Jun 9, 2001 | 09:23 PM
HuGEN's Avatar
Default Preparing to Drag
Fellow lude owners, I need some advice on what I need to prepared myself to be able to get the fastest time for my set up. This is the first time out on the track with this car. I have a 2000 Prelude with AEM CAI, AEM Cam Gears, Apexi N1 exhuast, Apexi V-AFC, MSD SCI w/blaster 2 coil, and Tanabe Sustec Coilover, also I'll be using stock rims. What do you guys suggest? Do I need to lower my car more? What about tire pressure? Should I buy new spark plugs wires and maybe more fuel to my car or should I lean it out. Give me some advice please. What times do you guys think I can get? Thanks
[Modified by LudeRacer, 6:37 AM 6/10/2001]
Old Jun 10, 2001 | 06:28 AM
tec-9-7's Avatar
Default Re: Preparing to Drag (LudeRacer)
Your stock plug wires are fine. Raise rear pressure to whatever the maximum for your tires is (probably 51-54 psi). Drop the front, raise the rear. W/ regards to V-AFC and cam gear settings, the only way to get anything meaningful is to spend the bucks for dyno-time - the track is not the place to sort out that kind of fine tuning. I would suggest you try runs both with and without the silencer tho, assuming you have one.
Paul
Old Jun 11, 2001 | 06:05 PM
BoM's Avatar
BoM
Default Re: Preparing to Drag (tec-9-7)
hope u don't have stock tires....cause stock tires suck....burn ur tires up realllllll good and launch high...shift hard and goodluck
Old Jun 12, 2001 | 03:34 AM
Big James's Avatar
New User
Default Re: Preparing to Drag (bommiE)
I would not burn up stock tires or any street tire for that matter. Bypass the water box completely. Street radials will actually lose traction when heated.
I would not lauch too high either. Feather the clutch, don't just dump it.
As far as the best setup for waht you have, dyno it. That is the only way to find out the truth. You could do adjustments at he track, but who is to say whether it was the car that got better/worse or you?
Old Jun 12, 2001 | 01:50 PM
HuGEN's Avatar
Default Re: Preparing to Drag (Jonesy69)
Thanks guys for your help, anymore advice would be great. Big James what do you mean by saying bypass the water box?Can you explian it to me a little more into detail. Thanks
Old Jun 12, 2001 | 01:53 PM
JG Luder's Avatar
what he means is when you are about to line up, about 30 ft behind the tree, there will be a "box" (small area) with water in it for you to light up your tires and heat them u pfor better traction. This is only benificial with slicks or drag radials. If you roast street radials, you will lose traction on launch.
Long story short, when you see water? Go around it. You'll half the folks go through it, and half go around... trust me, go around... or you'll have people laughing at you saying "why in the hell is he heating up street tires????"
Old Jun 12, 2001 | 05:14 PM
migo's Avatar
New User
FLAT SHIFT BABY.............................Go all out
Old Jun 12, 2001 | 05:26 PM
HuGEN's Avatar
Default Re: Preparing to Drag (D.specs)
Thanks alot guys. I really appreciate it. Anymore suggestion or advice? Thanks alot guys, and JG Luder thanks for clearing things up for me.
Old Jun 17, 2001 | 04:49 PM
HuGEN's Avatar
Well guys, I went to the drags on Saturday. Now I know how bad the stock tires suck. Anyways with the setup I got. I ran consistently 14.8 14.93. But with a horrible r/t of around 1.0 when I ran the 14.82 my r/t was 1.817. How horrible is that? Anywayz thanks alot for your help it made my first time experience fun. What do you guys think if I had a better r/t? Would i have a better 1/4 time? Thanks again
Old Jun 17, 2001 | 07:48 PM
migo's Avatar
New User
Good runs, R/T is only to tell you how you reacted towards. What was your 60 ft. and you MPH...Again those are good runs
Old Jun 18, 2001 | 10:31 AM
HuGEN's Avatar
My 60' was 2.320 and it was 14.8 @ 92.09.
Old Jun 19, 2001 | 01:49 AM
Big James's Avatar
New User
14.8 @ 92mph! Nto bad. I ran 14.8 @ 96mph w/o N2O. My 60ft was something like 2.2. Oh well, just keep practicing and you reaction times will go down. BTW, reaction times do not change your 1/4 time.
thehondaguru
Oct 2, 2009 02:34 PM
LDS
Oct 16, 2005 05:51 PM
2KGSRJD
Sep 30, 2002 12:55 PM
Red Rocket
Feb 14, 2002 09:03 PM
Asnprnc22891
Jun 21, 2001 06:16 AM
