Is this right???
Old Oct 14, 2005 | 02:59 PM
LDS's Avatar
LDS
Default Is this right???
I race my friends B20vtec dx hatch.
The car has the fallowing mods
CAI, 4-1 header, MSD Ignition, N1 Exhaust, AEM Cam gears, vafc and skuck 2 chip. He says it also has type r cams and skunk valve train. The car has ran (so he says) 13.0 @ 105 on drag rads.
Ok now the good part. My car ( h22 civic 4 door full weight with i/e, chip) ran 14.1 @ 97 in very hot weather on sticky tires. My best mph is 98.2 . Now the only thing i have done sence then is pump my tires from 20 psi to 35 and fix my shifter so i can shift a little quicker cause my other one was flopping around and bolted in with 2 bolts.
Ok so we race from 60- 120 and both of us stayed side by side. We raced 2 other times but we both fucked up so i dont count them. He says he would rape me from a stop but top end we are the same. My car does pull pretty good but i think with his setup he should of killed me no problem. So I ask what his settings are on his vafc and fuel pressure. He says his fuel pressure is set @ 60 psi and plus 6% on the high cam on the vafc. I think he is running way too rich for his setup. I have heard skunk 2 program on bseries runs rich even with mods. I think if he leaned it out some the car would pull from mine. What do you guys think? I also think he should lower his fuel pressure to 45 psi or so.
Old Oct 15, 2005 | 02:21 AM
91civicDXdude's Avatar
i think you both need to invest in a wideband
Old Oct 15, 2005 | 03:00 PM
LDS's Avatar
LDS
Your right, we do. But I still have a header and vafc sitting araound i need to put on first. Then im taking it for dyno tunning.
Ok well I guess thats all the input.
Old Oct 15, 2005 | 03:08 PM
raffiT78's Avatar
Default Re: (LDS)
well im a proud h22 fan, and have had a friend run a 12.8 in a 4 door eg that was all stock but I/H/E. the car completely gutted. Now when it comes to your friends settings, you guys just need to get it dynoed and i recommend hondata, for a couple reasons. Alot of people can tune them, and its inexpensive. i don't think there should be any adjustments done unless it is done on a dyno. each motor reacts differently to the smallest settings. I also think the prelude will do really well with a good tune. I do think you should invest in some good set of cams as well. you will see significant amount of hp. Good luck and long live H22
Old Oct 15, 2005 | 05:20 PM
FlsFinest
Guest
Posts: n/a
Default Re: (LDS)
to you sig. lol no i can chirp 2nd i canonly spin it and then chirp 3rd lol
Old Oct 15, 2005 | 05:30 PM
nsxmatt's Avatar
Default Re: Is this right??? (LDS)
Take his car to the track and see what it really runs.
Old Oct 16, 2005 | 05:51 PM
LDS's Avatar
LDS
Thanks guys for the info. He is going to dyno his car in a few weeks and as well as I. I did put my header on this weekend so maybe now I can hit 13s.
ImportechPerformance
May 10, 2003 05:02 PM
ludedudesi
Apr 4, 2003 08:56 AM
01-0720
Jul 9, 2002 04:55 PM
Trajic
Jul 3, 2001 12:55 PM
HuGEN
Jun 19, 2001 01:49 AM
