prelude turbo
Old Aug 29, 2004 | 06:35 PM
redlude04's Avatar
Default prelude turbo
i am thinking about a h22a for my 92 lude or my other option is a turbo but at first they would be about the same power gains but i would like to put the turbo at about 10-12 boost which do u guys suggest going with
Old Aug 29, 2004 | 06:42 PM
ItalynStylion's Avatar
Default Re: prelude turbo (redlude04)
Get the H22...then you can still boost later if you want
Old Aug 29, 2004 | 07:00 PM
SuperSlow's Avatar
If I had a 92s or si, I would definitely turbo it. It will walk all over h22 stock, and for the price of the swap complete, you could get a nice turbo setup on either f22 or h23. Do some searches on h23 turbos. Definitely worth the time.
Old Aug 29, 2004 | 07:34 PM
redlude04's Avatar
Default Re: prelude turbo (SuperSlow)
need more suggestions i know u guys got some
Old Aug 29, 2004 | 07:46 PM
vinuneuro's Avatar
im sorry, but it costs a lot to create a good turbo setup. Making it as reliable as NA is also going to be really hard.
Old Aug 29, 2004 | 08:33 PM
LudaMan's Avatar
Look what I can do!
Default Re: prelude turbo (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">im sorry, but it costs a lot to create a good turbo setup. Making it as reliable as NA is also going to be really hard.</TD></TR></TABLE>
agreed, either build the **** out of you motor, make sure its tuned and have an alternate source of transportation if you turbo. It depends on what you want. If you really want speed, go turbo, if you really want durability, go H22.
Old Aug 29, 2004 | 11:05 PM
Turck's Avatar
Default Re: prelude turbo (LudaMan)
It really just depends on what you want. The boosted engine would give you more power and a faster car, but it wont be as reliable as just a N/A h22. With turbo you gotta expect problems. Remember Moore's law! I'm thinking about building my own turbo setup for my h22a1 but im having engine problems already and i havent even boosted. I personally would go with boost but its a bigger risk and could end up costing you more in the end.
Old Aug 30, 2004 | 06:39 AM
preludeez's Avatar
Default Re: prelude turbo (Turck)
what is the state of your current engine??? mileage, compression, leakdown???
your motor maybe able to handle some boost....but like mentioned above - the H22 will be more reliable.
Old Aug 30, 2004 | 06:55 AM
blackdelslo's Avatar
Default Re: prelude turbo (preludeez)
h22......turbo, that would be sweeeeeeeeeet
Old Aug 30, 2004 | 07:48 AM
lildrgn2.0's Avatar
New User
fast , cheap , reliable
pick two.
Nikoli's Avatar
Default Re: prelude turbo (delLudeVTEC)
unless your gonna fully build the h23/f22 then i wouldnt go turbo. but...if you can afford to do a nice build then i would deffinately go turbo . if you cant go forged and get hondata then i would go with h22
Old Aug 30, 2004 | 07:53 AM
redlude04's Avatar
Default Re: prelude turbo (Deckedlude)
my h23 has 162,000 miles on it still running strong no problems but instead of buying a h22a i was thinking just buying the head and then going turbo but the turbo im looking at says its for a h23 as soon as i put the h22 head on it will it still work i mean there basically the same motor except fpr the h22 has the cams and performnace parts
Old Aug 30, 2004 | 08:59 AM
preludeez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">unless your gonna fully build the h23/f22 then i wouldnt go turbo. but...if you can afford to do a nice build then i would deffinately go turbo . if you cant go forged and get hondata then i would go with h22</TD></TR></TABLE>
x2
word.
Old Aug 30, 2004 | 04:24 PM
ekHseries's Avatar
h22a is overrated, i would just build a h23 and turbo it
Old Aug 30, 2004 | 04:59 PM
Freemantle's Avatar
Well... are you saying making a 275 hp turbo setup as reliable as a 275 hp n/a H22 setup? I don't think you are right. Let's compare apples to apples. For high power, boost is much more reliable than all motor.
Old Aug 30, 2004 | 07:43 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlude04 &raquo;</TD></TR><TR><TD CLASS="quote">my h23 has 162,000 miles on it still running strong no problems but instead of buying a h22a i was thinking just buying the head and then going turbo but the turbo im looking at says its for a h23 as soon as i put the h22 head on it will it still work i mean there basically the same motor except fpr the h22 has the cams and performnace parts</TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekHseries &raquo;</TD></TR><TR><TD CLASS="quote">h22a is overrated, i would just build a h23 and turbo it</TD></TR></TABLE>]
Old Aug 30, 2004 | 08:19 PM
redlude04's Avatar
i have another question the turbo im looking at says for h23 which i have but im also lookin at a h22a head to put on would that turbo still fit on the motor ? it should shouldnt it? thanks for the post
Old Aug 30, 2004 | 08:32 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlude04 &raquo;</TD></TR><TR><TD CLASS="quote">i have another question the turbo im looking at says for h23 which i have but im also lookin at a h22a head to put on would that turbo still fit on the motor ? it should shouldnt it? thanks for the post </TD></TR></TABLE>
No. Different flanges. Is this not the same question I just answered?
Old Aug 30, 2004 | 10:00 PM
vinuneuro's Avatar
I dont think u understand how much there is to putting H22 head on H23 block (H23VTEC). You dont jsut swap them. There is a lot of other stuff u have to do as well.
Old Aug 30, 2004 | 10:44 PM
fexea01's Avatar
the more thebetter
WillSB
Nov 25, 2008 03:07 PM
HondaVTEC1993
Oct 9, 2005 08:40 PM
sohcvtec1995
Sep 16, 2003 12:05 PM
EH2DX
Mar 23, 2003 08:01 AM
mugensport9
Dec 21, 2002 08:33 AM
