Prelude Problem?
I have a 1993 prelude with an h22a engine swap its a 5 speed manual but whenever we try to start the car it burns up the ecu. We have never had the car running we baught it this way and have tryed to put in a new ecu and tryed setting up new grounding wires checked all fuses and still nothing. Has anyone else had the same or similar problem or know a fix for this?
Im assuming that you dont have that, in that case the ecu you need is a p13.
Adding more grounding to the ecu is not the direction I offered.
You need to make sure that all the power wires are giving off the 12v signal, and that the ground wires are giving the negative 12v.
No it is not. Unless you have a chipped ecu with a base map for the h22.
enigma94
Oct 26, 2006 04:07 PM
