Prelude Header Update
Old Mar 19, 2002 | 11:43 AM
SMSP's Avatar
Default Prelude Header Update
Corey's car is coming to the shop Thursday. Work to start soon, we'll keep you posted. May actually do a 4-2-1 and a 4-1 for the first round.
Old Mar 19, 2002 | 12:17 PM
Fly1865's Avatar
Default Re: Prelude Header Update (SMSP)
HELL YES!!!!!!
Old Mar 19, 2002 | 12:19 PM
prelude10's Avatar
Default Re: Prelude Header Update (Fly1865)
Post pics please, when you have them, WEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
Old Mar 19, 2002 | 01:35 PM
H22pwrd's Avatar
You have mah money. Actually Jeff would, since your headers would come with his H22 crate motor. More power.
Old Mar 19, 2002 | 04:20 PM
laughinxxx's Avatar
New User
Default Re: Prelude Header Update (Jonesy69)
Old Mar 19, 2002 | 05:14 PM
illusion's Avatar
Default Re: Prelude Header Update (laughin2.2)
im very very interested but i need to be sure that this will still be streetable. i was confused with the last posts that it wont bolt up to the stock cat? so that means that i wouldnt be able to use my cat or a normal cat back exhaust like a greddy either?
Old Mar 19, 2002 | 06:05 PM
SMSP's Avatar
Default Re: Prelude Header Update (illusion)
The collector will be 2-1/2" on either the 4-2-1 or 4-1 so no it won't bolt to a stock cat and you wouldn't want it to. You'll need a new 2-1/2" cat and then mod your B pipe to bolt to the cat outlet. If you want improvements the whole system needs to be changed.
Old Mar 19, 2002 | 06:23 PM
SMSP's Avatar
Here are some ITR pictures.
This is the stock B Pipe flange. It actually measures just 1.9" OD/1.75" ID and then opens to 2.25" OD
The following is how I build my 2-1/2" cat backs for the ITR and this is also the same thing I do with my adapters.
Here's an adapter that measures 2.50"+ ID at the inlet and 2.375" OD at the outlet to be used with 60mm systems.
Here's a picture of the 60mm Tanabe system for the ITR but it has a 2" OD x 2" long bottle neck at the start of the B Pipe. This pictures shows the bottle neck cut out and the above adapter installed. This alows for a smooth transition from the 2.50" ID outlet Carsound cats to any size B pipe. This simple mod yield a 4whp gain on a stock ITR with just an AEM, Toda Header and 2-1/2" cat.
The customer was driving the car with the cat and Tanabe as received for 2 weeks prior to the mod. You can see where the exhaust was depositing on the face of the Tanabe flange due to the mismatch. This causes turbulence and some people report hearing a "whooshing" sound.
[Modified by SMSP, 7:27 PM 3/19/2002]
Old Mar 19, 2002 | 09:24 PM
Honda318dx's Avatar
I am SO psyched about this! With this header, and a few other goodies, i should be able to run from ITRs with ease.. Well, I hope anyways..
Guys, if Dave can make something up with a 2.5" collector, it will really unleash the potential of this motor, all preludes are stuck with a 2" bottleneck... Start saving..
Old Mar 19, 2002 | 09:41 PM
smokin rubber's Avatar
Default Re: Prelude Header Update (Honda318dx)
and you might need to use your brakes
good luck with the header, I might even need one some day
Old Mar 19, 2002 | 10:36 PM
Greyout's Avatar
Default Re: Prelude Header Update (smokin rubber)
just out of curiosity, incase I missed the post - what size primaries were you going with?
Old Mar 20, 2002 | 05:41 AM
Chris93Si's Avatar
Hmmm, time to start saving
Thanks for the update.
Old Mar 20, 2002 | 06:12 AM
illusion's Avatar
Default Re: Prelude Header Update (Chris93Si)
hmm ok. so if i were to go with this system, id need the header, a new 2.5" cat, and an adapter of some sort to use an aftermarket exhaust (either Greddy SP or RS*R) to work with the cat.
now, will this larger header and bigger cat greatly affect the sound of the vehicle? or will that ultimately depend on the muffler and exhaust?
also, corey.. you should dyno the car before you put the header on, and then again afterwards, to show the gains.
Old Mar 20, 2002 | 08:18 AM
Honda318dx's Avatar
don't worry, we will
I'll leave all technical questions to Dave...
Old Mar 20, 2002 | 08:31 PM
illusion's Avatar
Old Mar 21, 2002 | 10:27 AM
98Luder's Avatar
it'll be interesting to see how well a 4-1header works on a H22A.
I don't think there has ever been one available. I'm excited to see the results as well. Good luck guys
Old Mar 21, 2002 | 10:38 AM
illusion's Avatar
Default Re: Prelude Header Update (98Luder)
well i just read: http://www.team-integra.net/sections...sp?ArticleID=2
i am also concerned that if i use a regular aftermarket exhaust like greddy sp (60mm?) that the exhaust will bottleneck the header/cat and make the gains negligible.
Old Mar 21, 2002 | 10:40 AM
98Luder's Avatar
yea that was one of my concerns as well...
how a 60mm exhaust will effect the system. Any insight on this Dave?
Old Mar 21, 2002 | 11:35 AM
Greyout's Avatar
*cough* custom *cough*
also, a 60mm pipe will less of a restriction the further away from the collector you get, due to the exaust gasses slowing down & cooling a tiny bit.
(one reason I've never understood why the PE goes from 60mm to 70mm, instead of 70mm to 60mm
[Modified by JDM LUDE, 8:36 PM 3/21/2002]
Old Mar 21, 2002 | 11:36 AM
98Luder's Avatar
Default Re: Prelude Header Update (JDM LUDE)
yea custom would be nice, I just didn't wnt to get rid of my Mugen catback. However, I'll see how the power gains turn out first from the R&D they do on this guys Prelude.
Old Mar 21, 2002 | 11:38 AM
illusion's Avatar
i dont want the sound of a loud obnoxious exhaust. rs*r or greddy sp are supposed to be somewhat easy on the ears compared to others.
Old Mar 21, 2002 | 07:43 PM
SMSP's Avatar
If you have a 60mm system don't get rid of it yet. While I think a 2-1/2" system would be better you shouldn't be too bad off with the 60mm as long as you make a smooth transition from the 2-1/2" cat or test pipe to the 60mm tubing. However, if you are building a system to replace your stock one then go with 2-1/2".
Old Mar 21, 2002 | 08:11 PM
bgod's Avatar
smsp, so basically you'll also be providing the adapter for the 60mm exhausts like you do with the b18 headers. reason is i already have a 60mm exhaust like most above.
if the adapter is included or an option for a bit more i'm definitely in. i just wouldn't want to waste all this money on a header and have turbulence going into the b-pipe.
are you taking deposits yet? and will this fit correctly on a 4th gen. prelude h22a.
Old Mar 25, 2002 | 04:09 PM
SMSP's Avatar
Default Re: Prelude Header Update (bgod)
The adapters I make for the other cars bolt to the cat outlet and then the customer gets them welded to their exhaust. I build them with 2.50" IDs x 2.25" or 2.38" OD outlets. The B pipe gets cut, expanded and the adpater slides into the B pipe and then gets welded.
BTW, I'm glad my wife and I have had all our kids because I think I'm going to damage my family jewels getting in and out of this car. I'm a bit bigger than Corey and it's almost comical watching me getting into and out of this thing. Once I'm in, my eyes are level with the roll cage and my head is almost hitting the sunroof (no headliner either!). I could never drive it on the track set up like this. How tall are most of you guys who drive these? I have a friend who's 6'-3" or 6'-4" and he's thinking about getting one of these and I just don't see how he would fit.
Old Mar 25, 2002 | 04:23 PM
Chris93Si's Avatar
Haha, I'm 6' and sometimes my head grazes the ceiling when I lean forward. It's kinda like you fall in and you climb out
