Power windows not working
Old Dec 27, 2010 | 07:47 PM
oneoffaccord's Avatar
Default Power windows not working
I got a 92 prelude si auto. Long story short i got the car for $150 little over a year and i need work. got it all put back together but my only thing is that the power windows dont work. heres what i checked
1. fuse 10 under dash fuse block is getting power.
2. fuse 15 and 16 are not getting power.(left and right windows)
3. power window fuse under hood is fine. big 40 amp fuse.
4. interior lights fuse is good. this goes to intergrated control unit at under dash fuse block
5. the ground underneath the driver seat is fine.
6. havent checked ground under or behind front console.
7. replaced under dash fuse box/block with another one
8. swapped power window relay
has anyone came into this problem? in order for me to finish up the interior the drivers window has to go up.
Old Dec 28, 2010 | 03:10 AM
Default Re: POWER WINDOWS NOT WORKING
43 views no love?
Old Dec 28, 2010 | 05:29 AM
jkoni426's Avatar
Just going by the Helms I would check out fuse 17 (30 A) in the under-hood box. If that's good, sounds like you did everything else but check grounds 401 & 402 located on the left side of the shifter and the right side of the dash. It also says to check for an open in the white/blue wire.
Old Dec 29, 2010 | 02:19 PM
Default Re: Power windows not working
thanks man. im going to check it out agian
Old Dec 29, 2010 | 03:31 PM
got the windows to work. there was a plug just laying there no nothing, couldnt figure out where it went to. i looked underneath the fuse box way at the bottom and there was a port not being used. plugged that it and it work. wtf
Old Dec 29, 2010 | 04:14 PM
AyOhOndA's Avatar
Lmao, always the first thing to check. 'Loose and Dirty connections.' That's was my instructor in Auto Service Tech's Motto I swear.
Old Dec 29, 2010 | 09:24 PM
i know that but i got the car taken apart. alot of things were missing when i got it
osbunjosh
50
Jan 29, 2024 05:20 PM
snowblind7x
Mar 2, 2019 12:12 PM
Sepulveda87
May 1, 2015 04:53 AM
EDWINV00SI
Jan 19, 2011 08:39 AM
free99
Audio / Security / Video
Mar 6, 2007 12:14 PM
