Post your setup here
Ride : 95 S BA8 with a few mods....
History
Originally equipped with a F22A and slushbox, the car has been treated to a JDM H22A with a M2B4 LSD conversion.
Propulsion
Internally the H22A is stock but has been thoroughly refreshed.
Breathing life into the engine is dutifully performed by a JDM Type S intake. Expelling the exhaust is an Xforce S10 Twinloop.
Getting the power to the wheels is a lightweight 8lb Cromoly Flywheel and Daikin Exceedy Clutch taking the honours.
Spark is obtained using NGK 8mm leads and NGK ZFR11a's. Oil cleanliness is provided by an OEM Toyo Roki filter, filled through a polished Mugen oil cap.
Ensuring timing stays in check is a H23A manual timing belt tensioner, converted for peace of mind. Radiator is topped off with a Mugen cap adding an little bit of class. A Fluidyne aluminium radiator is to be added shortly.
Whilst the engine was out of the car, it received a full detail incliding manifold, head, block and accesories, giving it a Type S look.
Rims and Tires
Rolling on custom powder coated 17" x 7.5 Rota Formules, shod with Bridgestone Potenza GIII tires providing the grip.
Resistance
Upgrading from the stock rotor size came in the form of OEM VTiR Calipers and 282mm rotors, with added bling in the form of red colour coded brake calipers with custom "Honda" stencilling in white.
Stance
Koni Yellow/Eibach combination.
Spoon Strut Brace Front and Rear
Body - Outside
Treated to a baremetal respray in PPG 2K Maserati Mediterraneo Blue Pearl, custom touches that require the keen eye to spot are there.
JDM accessories abound in and around the car, most notably:
Genuine Mugen front bumper and headlight covers.
Customised Genuine Mugen Accord Side Skirts.
BB6 glass sunroof.
JDM Mitsuba Alpha II twin horns for pedestrian warning.
JDM Window Deflectors.
Custom cleared tail lghts.
Shaved bonnet with Custom washer jet relocation to wiper arms.
Clear/amber Stanley indicator set and side repeaters.
Custom brushed aluminium kick plates with Prelude logo's.
Chrome Rear Garnish strip with engraved Mugen logo
Shaved bootlid, with BB6 Prelude Lettering
JDM Black one piece headlights.
JDM Power Folding Mirrors.
Shaved Arial with Rear demister circuit arial and Frequency shifter so JDM radio works on our frequency
Body - Inside
The car is currently loving its accessories :
JDM Climate control swap
JDM Honda Access Air Refiner
JDM Gathers Double DIN Minidisc/CD/Radio/Tape unit and Pioneer 6" 3 Way Splits Speaker Set
JDM Emergency Flare and Bracket
JDM Prelude Floor Mats
JDM Honda Fit Map Lights
JDM Leather Interior with electric seats
OEM S2000 Start Button
Mugen Sports Pedal Kit
JDM DC2 Integra gearknob
Momo OEM JDM steering wheel
Future modifications are a custom quad throttle setup, Hondata S300 ECU and upgrading of valve train and strengthened internals. This will then be topped of with some custom headers, possibly RMF or SMSP and then the car will be finished, maybe!
Future plans if the car is still around, will be a complete interior retrim and upgrading of instrumentation.
Modified by skinnyboy at 7:51 PM 10/6/2006
History
Propulsion
Rims and Tires
Resistance
Stance
Body - Outside
BB6 glass sunroof.
Body - Inside
[QUOTE=shutta]I talked for a minute with precisionH23a about this and he seemed ok with the idea but hasn't gotten back to me so I figured i'd give this a try, he can take this thread down if he thinks we shouldn't have it up yet.
Post a maximum of 2 pictures of your car , your info/car info, list a brief history of the car if you want, current modifications, and future plans
DO NOT PUT ANY, absolutely ANY responses about ANY cars in this thread, PM THE OWNER!!! this isn't going to turn into the prelude pictures thread where there are more replies than pictures. IF YOU CAR CHANGES, MODIFY YOUR ORIGIONAL POST!
THIS LIST OF RULES WILL BE QUOTED ON EVERY NEW PAGE OF THIS THREAD SO NOBODY HAS EXCUSES THAT THEY DIDN'T READ THE RULES.
Car: 95 Prelude Si
History: I bought this car myself when I was in college for computer animation and I did not know ANYTHING about cars at the time. I was so proud of it and I had stupid ricer mods like altezza lights and a crappy muffler. It got me through school and after I blew the engine I realized I needed to stop being an idiot at the street races and I found Honda-tech. From then it was research and buy good stuff for it to ultimately have nice turbo & suspension setup. I love my Prelude and hope to have it forever.
My car currently has a really crappy ghetto paint job that I actually don't mind because I don't have to worry about it, hehe. It also needs some body work, but hopefully it lowers people's expectations when they first see the car.
The stuff actually on the car now is listed here and most of the turbo and uninstalled stuff that's in my closet is listed at the end.
Suspension-
-D2 Coilovers (8k)
-Progress rear sway bar
-Removed front sway bar
-Custom rear endlinks
-ES greasable swaybar bushings
-New UCAs, tie rod ends, ball joints, etc
-15” Volk TE-37 w/ 5mm spacer
-Decent 205 55/15 tires
-ARP extended lugs
-Muteki lug nuts
-EM Racing C-pillar bar
-DC Sports rear lower tie bar
Engine-
-Custom intake w/ Apex’i filter
-Edelbrock 70mm throttle body
-TB coolant bypass
-Greddy oil catch tank
-Hondata IM gasket
-AEM fuel filter
-AEM fuel rail w/ liquid filled gauge
-AEM fuel pressure regulator
-Walbro 255 lph fuel pump
-ST Corsa cam gears
-DC sports header
-Custom 2.5” exhaust piping
-Carsound high flow cat
-Magnaflow muffler
-UR crank pulley
-UR alt pulley
-Removed power steering & AC
-Innovative motor mounts
-Removed entire EVAP system
-Upgraded OEM ground wires with Aerospeed
-NGK plugs and wires
-K&N breather
-Fidanza 8lb aluminum flywheel
-STR ‘blade’ dip stick
-KMS EGR block-off plate
-Magnetic drain plug
Cooling-
-Civic 2” thick aluminum radiator
-OBX silicone rad hoses
-12” slim fan mounted pusher style
-Billet specialties overflow tank
Transmission-
-Exedy cerametallic 3-puck ‘thin disc’ clutch & pressure plate
-Forbidden motorsports short shifter
-Fox-stock heavy shift ****
Weight Reduction-
-VIS CF hood
-Lighter-faster CF sunroof plug
-Complete rear interior removed….everything
-Sound deadening material removed
-Dash & HVAC system gutted
-All carpets removed
-JDM front bumper support
-Rear bumper support removed
-Entire audio system removed
-Excess door & unibody material removed
-Aluminum bolts used wherever possible
Aerodynamics-
-APR CF mirrors
-95 Accord rear skirts
-Ichiban rear bumper diffuser
Brakes-
-New OEM Si calipers
-Brembo drilled Si rotors
-Hawk HPS pads
-Russel SS brake lines
-Entire ABS system removed
Interior-
-Custom mounted Defi BF gauges
-----Oil pressure
-----Engine temp
-Momo Monte Carlo steering wheel in 320mm
-Momo Steering wheel hub
Exterior-
-JDM black housing headlights
-Ford blue paint
-’Car’ emblem on rear
-Other emblems shaved
-Shaved antenna
-Godspeed Civic hood shocks
-Mr Gasket hood locks
Not-yet-installed stuff-
-JDMsh!t Spoon replica front lip
-Forbidden motorsports cooling plate
-ExplicitSpeed D-series upper alt. bracket
-85amp D-series alternator
-ARP head studs
-Tial waste gate
-Tial blow-off valve
-Rocket titanium retainers
-Rocket valve springs
-PFI traction bar setup
-Lovefab Mini-me manifold
-Kaizenspeed balance shaft eliminator kit
-Spare H23 in the garage to get built for boost (5k saved for it so far)
-SS clutch line and fittings
-New clutch slave and master cylinders
Future plans/purchases-
-CF trunk
-Sleeved block
-Intercooler piping
-Intercooler
-T3/T04e (not sure on sizes yet)
-Defi BF boost gauge
-PLX wideband
-Hondata
-Downpipe, oil lines, other turbo crap.....
-CF seats
-Fiberglass OEM fenders
-RC injectors (also not sure on size yet)
-Moroso oil pan
-Maybe some window tint or better paint
Car: 95 Prelude Si
Suspension-
-D2 Coilovers (8k)
-ARP extended lugs
-Muteki lug nuts
Engine-
-TB coolant bypass
-Hondata IM gasket
-AEM fuel filter
-ST Corsa cam gears
-DC sports header
-Magnaflow muffler
-UR crank pulley
-UR alt pulley
-K&N breather
Cooling-
Transmission-
Weight Reduction-
-VIS CF hood
Aerodynamics-
-APR CF mirrors
Brakes-
-Hawk HPS pads
Interior-
-----Oil pressure
-----Engine temp
Exterior-
-Ford blue paint
-Shaved antenna
-ARP head studs
-Tial waste gate
-CF trunk
-Sleeved block
-Intercooler piping
-Intercooler
-PLX wideband
-Hondata
-CF seats
-Moroso oil pan
Car: 92 Prelude Si
History: originally i had an auto prelude S. i really was not into car performance but i took an automotive course and met some car enthusiasts. then that is when started getting into fixing up the prelude. auto trannys suck so i wanted to manual trans conversion but i found it easier and cheaper to trade it in. i was looking for a vtec model but it was not in my budget at the time. i found the Si in good conditions and with in my price range.
Suspension-
stock
Engine-
-NOS single fogger(jetted at 80fhp)
-Crower cams stage 1
-removed balancer shaft belt
-TB coolant bypass
-Hondata-style IM gasket
-AEM fuel rail w/ NOS liquid filled gauge
-DC sports header
-Magnaflow muffler
-K&N filter
Transmission-
-Centerforce stage 2 clutch
Brakes-
stock
Exterior-
-oem foglights
-wingwest RS front lip
Future plans-
well i want my lude to dip into the low 13 and then ill call it quits.
Car: 92 Prelude Si
Suspension-
stock
Engine-
-TB coolant bypass
-DC sports header
-Magnaflow muffler
-K&N filter
Transmission-
Brakes-
stock
Exterior-
-oem foglights
Future plans-
Ride: 95 Prelude Si
History: I had a 3rd gen lude once and loved it, but the timing snapped and bent all the valve. I was 16 so didnt even want to mess with it. After have a couple other cars and having one stolen, I was determined to find a newer Lude. so driving around in my rental car one day i spotted it at a dealer, stopped and to my suprise it was only $3000 with 50,000 original miles. couldnt believe it, so naturally i bought it but got it for 2800 cash. So to make a long story short just been builing and loving it.
Suspension
-Tien Flex with EDFC
-Suspension Techniques f&r sway bar
-Nuespeed front tower bar
-Tenabe f&r lower frame braces
-Energy Suspension master bushing set
Engine
-full port and polish
-dc header
-aem cai
-aem pulleys
-aem fuel rail(will have regulator and gauge in 2 days, bought for turbo)
-aem cam gears
-bdl 70mm tb
-helix tb spacer
-aerospeed grounding kit
-nology hot wires
-high flow cat with custom exhaust and brullen muffler
-egr removed
-ac removed
-innovative motor mounts
-nrg engine damper
-apexi s-afc2
Transmission
-exedy clutch
-clutch master lightweight flywheel
-driveshaft shop stage 2 axles
Brakes
-Rotora slotted rottors
-Russel ss brake lines
-aem pads front
-hawk pads rear
Exterior
-accord rear lip
-jdm bumper lights
-amber side markers
Future plans
-turbo in feb
-hondata s300
-building new block
-cf hood and trunk lip
-jdm black headlights
-explicit traction bar
Ride: 95 Prelude Si
Suspension
Engine
-dc header
-aem cai
-aem pulleys
-aem cam gears
-bdl 70mm tb
-helix tb spacer
-nology hot wires
-egr removed
-ac removed
-nrg engine damper
-apexi s-afc2
Transmission
-exedy clutch
Brakes
-aem pads front
-hawk pads rear
Exterior
-accord rear lip
-jdm bumper lights
-amber side markers
Future plans
-turbo in feb
-hondata s300
-building new block
98vtec
Jun 22, 2016 11:29 PM
vinuneuro
May 2, 2010 08:52 AM
vinuneuro
Mar 2, 2010 11:06 AM
