Please Help!!! Distributor Question
Old Jan 20, 2002 | 11:35 AM
Astr8upfella's Avatar
Default Please Help!!! Distributor Question
Hi there. Okay, if anyone can help me and it works I will send you 10 bucks via paypal. I have an obd2 car(96 honda accord). I just put in a obd1 h22a(honda prelude vtec). I'm using the obd1 ecu and the skunk2 obd2 to obd1 converter. The question I have is with my distributor. I'm using my old accord obd2 engine wiring harness. Everything matches up except the distributor because the distributor is obd1. Any help on how to hook it up. Do I need a obd2 distributor??? Does anyone have distributor wiring diagrams for obd1 and/or obd2. Any help would be very appreciated. Thanks. Chris
Old Jan 20, 2002 | 11:42 AM
laughinxxx's Avatar
New User
Default Re: Please Help!!! Distributor Question (Astr8upfella)
Is it a JDM motor?
Old Jan 20, 2002 | 11:44 AM
Yes it is a jdm engine.
Old Jan 20, 2002 | 11:45 AM
laughinxxx's Avatar
New User
Everything else bolts up. Depending if your motor is JDM or not, but if you use a JDM motor.. the distributor will have an internal coil where as the USDM counterparts use external coils... What you need to do is wire up the JDM dist. to use the internal coil.. One of the wires on the USDM coil harness has to be jumped inorder for the JDM coil to fire up.
I found this by searching the hybrid forum.
Old Jan 20, 2002 | 11:52 AM
I'm still kind-of confused on what I need to do. I'm using a msd ignition with an external blaster coil. Is there a way I can call you, you can email me, or instant messange me if you have aol??? My email address is Astr8upfella@aol.com and my im name is Astr8upfella. Thanks a bunch. Chris
Old Jan 20, 2002 | 11:59 AM
laughinxxx's Avatar
New User
I am just regurgitating info that I looked up. I don't have any experience with this swap.
FreshCD5
Jun 2, 2011 01:25 PM
RPM JDM
Oct 8, 2009 09:38 AM
PTVDesign
Feb 11, 2009 01:18 AM
Astr8upfella
Jan 21, 2002 10:53 AM
Astr8upfella
Jan 20, 2002 01:30 PM
