Please Help...
Old Oct 15, 2001 | 09:50 PM
SpdFrk's Avatar
Default Please Help...
Today when I was at work I washed my engine. Then when I started it I noticed the car was idling pretty rough, the needle kept going up and down and in some cases the car would stall. Then the check engine light came. So I asked the mechanic if he could take a look at it( I work at acura) so he puts it up to this machine and he sayes that cylinders 1&2 are mis-firing.
He took my spark plug cover off and all the cylinders where full of water, so he took a air gun and blew all the water out. But the check engine light is still on and it still idles rough. He couldn't have time to fix it because we where closed. What Does anyone know what could be the problem..
It's a 2000 Prelude 5spd with just a AEM cold Air, sparko wires and N1 exhaust.
Old Oct 15, 2001 | 09:58 PM
JG Luder's Avatar
Default Re: Please Help... (00Lude)
You didn't clean out all the water. I'd leave the plug wires off overnight (that is if it's nice outside) and let it completely dry out. Also, make sure the rotor cap is dry.
Start there and let us know what happens.
Old Oct 16, 2001 | 09:46 PM
SpdFrk's Avatar
Default Re: Please Help... (JG Luder)
Thanks it ALOT better know, its know idling like it was before and when i took it to my mechanic he did a compression test, all 4 cylinder are at 180psi and the car is running good but the check engine light is still on, should i just reset my ECU?
Thank you..
Old Oct 17, 2001 | 11:15 AM
HondaDriver4Life's Avatar
how did you wash your engine btw....did you use a high-pressure water gun??
Old Oct 17, 2001 | 01:37 PM
SpdFrk's Avatar
Default Re: Please Help... (HondaDriver4Life)
no, i just filled a bucket with water and dumped it on the engine.
Old Oct 17, 2001 | 01:39 PM
SpdFrk's Avatar
I used this soap that we have, its only for cleaning engines...
JusAccord
Jan 15, 2012 11:03 AM
PaChiLa Leader
May 8, 2008 05:05 PM
teggytegteg
Jan 8, 2006 10:50 PM
pr0jektdc2
Nov 27, 2004 07:19 PM
RH-TEG
Jun 25, 2003 07:08 PM
