overheating issue
Old May 28, 2009 | 11:50 AM
fraserboostedh22's Avatar
Default overheating issue
hey guys, does anyone knows why my car wants to overheat climbing uphill? and when i make a sharp left curve, the temp come back down. normal driving is ok. i've flushed the system really good, change thermostat and i'm not using antifreeze. thks much!
Old May 28, 2009 | 12:23 PM
shooter93's Avatar
Default Re: overheating issue
u should use antifreeze, although it won't move the heat away from your motor like water will, it lubes the pump, with out it you killin your pump!
Old May 28, 2009 | 12:29 PM
Kronn 98SH's Avatar
Honda designed the coolant system to run 50/50 water & antifreeze. Straight water causes corrosion, freezing, and premature boiling. Are you sure the car is overheating and it's not just the temp gauge acting up?
Old May 28, 2009 | 01:20 PM
****. didn't know that. thks alot
Old May 28, 2009 | 01:23 PM
i think my gauge is fine. before the temp goes up, the check engine light comes on. when i am driving flat land , its fine. damp, i better put some coolant in there. thks.
Old May 28, 2009 | 01:47 PM
would u guys reconmend a new bigger radiator?
Old May 28, 2009 | 01:53 PM
Kronn 98SH's Avatar
No. First you should determine your problem. If the CEL comes on, pull the code. My car has overheated several times and I never received a CEL.
Old May 28, 2009 | 04:12 PM
Rkwan87's Avatar
check all hoses
radiator
the last time you change your water pump
fan
water level
i might be missing something
please feel free to add people
Old May 28, 2009 | 05:01 PM
some guy on the forum told me there's no code. it just tell me to look at the gauges and my tuner told me the same. thks again . i've been frustrated with the problem for awhile.
Old May 28, 2009 | 05:04 PM
Originally Posted by Rkwan87
check all hoses
radiator
fan
water level
check everything. no leaks, two new fans and working fine. except the water pump was 31,000 mls ago. thks though
Adankid
19
Jan 17, 2009 02:20 PM
hotaccord243
Oct 8, 2008 11:54 AM
chbtek9
13
May 18, 2004 12:46 PM
toohott4handlin
21
Feb 8, 2004 03:47 AM
planeman01
Oct 28, 2002 03:22 PM
