Oil Cooler
This morning i started my car and let it warm up for probably around 7 mins. I go back outside and see the car shooting oil all over. It turns out its leaking from somewhere around the oil filter, I believe its the cooler o ring because it looks like it coming from closer to the block than the filter itself. Anyway Im having a hard time breaking it loose, what is everyone else using ?
It weird though that I was working on the car saturday night and everything was fine no leaks anywhere and now its leaking ALOT. I didnt touch anything near that so I dont think its anything I did. Is it possible for an oil cooler oil ring to all of a sudden leak alot ?
definitely the oil cooler. It's very fast to change out if you have a 1/2" drive, the gasket and the right size socket. Mine squirted oil for a mile and was everywhere.
Its a 30mm correct ? This is on a 98 SH BTW. Also do I need to drain the coolant from the radiator and block ?
Modified by kornerk12 at 6:15 PM 10/16/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 »</TD></TR><TR><TD CLASS="quote">Is it possible for an oil cooler oil ring to all of a sudden leak alot ? </TD></TR></TABLE>
It is very possible, and due to a temperature drop. The rubber shrinks in the cold and and cracks.
Well its pouring rain here all day so hopefully tomorrow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jagan’92 »</TD></TR><TR><TD CLASS="quote">
It is very possible, and due to a temperature drop. The rubber shrinks in the cold and and cracks.</TD></TR></TABLE>
Yea that makes sense because it was cold that night
I changed the o ring and it didnt wanna stay on i tryed for a good 30 mins tryin to make sure it was sitting on there and thought i finally had it. Anyway I go to start the car and i loose atleast 2 quarts of oil withing 5 seconds. I felt around the o ring and nothing was sticking out it seemed like it was on there. Its a bitch though because i tryed to get it on there without disconecting the oil cooler from the oil lines because it seemed like if i took it off i wasnt gonna get that back on. Also i changed the oil filter just in case that had anything to do with it and that was on there tight also. This is on an SH and im looking at the diagram there is actually another seal behind a mounting bracket that the oil cooler sits on. Anyone have any ideas ?
by oil filter o ring do you mean the o ring on the actual oil filter or am i missing somethin on the oil cooler because i dont remember anything on the oil cooler besides the o ring on the opposite side
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 »</TD></TR><TR><TD CLASS="quote">by oil filter o ring do you mean the o ring on the actual oil filter or am i missing somethin on the oil cooler because i dont remember anything on the oil cooler besides the o ring on the opposite side </TD></TR></TABLE>
The o-ring on the actual filter. Very often they stick to the block when you take the old filter off, and then you put the new filter on and you have 2 o-rings in there. Doesn't usually seal very well...
Na theres no o ring on there. Anyway the oring does not wanna sit and everytime i move the cooler towards the block after putting the oring on the oring falls or moves off, it doesnt wanna sit in the slot.
Thanks but I have the big *** honda manual the one thats like 1000 pages. But i dont remember seeing a torque spec in the book for that bolt but i could be wrong.
