obd question
Old Sep 26, 2001 | 07:59 AM
carolinaACCORD's Avatar
Default obd question
what is the difference between the different series of obd, and also what series came on which year preludes?i just want to know.
Old Sep 26, 2001 | 09:20 AM
aklucsarits's Avatar
New User
Default Re: obd question (HONDApowerEXTREME)
On Honda Preludes...
Pre 1992 - I don't know
1992-1995 - OBD1 - Basically just used by techs as a diagnostic tool. Does not really do too much emissions-wise. Does not hinder performance very much if at all.
1996-1999 - OBD2 - secondary O2 sensor added. Compared to OBD1, the ECU is far more aggressive at retarding timing when emmissions exceed standards. This generally reduces effectiveness of bolt-on upgrades.
2000-2002+ - OBD2ver2 - Some people make this distinction for cars 2000 and later. I don't know what the difference in performace or functionality vs. "OBD2".
Andrew
Old Sep 26, 2001 | 10:58 AM
Default Re: obd question (aklucsarits)
thanks for the info.
is there any way to switch from obd2 ver. 2 to obd 1?
will i just have to have the computer and harness?
Old Sep 26, 2001 | 11:15 AM
New User
It's not that easy... On a 97+ Prelude, to switch to OBD1, you need:
1993-95 P13 ECU
OBD2->OBD1 wiring harness adapter
OBD1 h23 or h22a distributor with all sensors
Modify the distributor wiring harness for OBD1 distributor
AND either one of the following:
1993-1996 H22a peak and hold type fuel injectors
OR
"Resistor pack" from the fuel injector wiring harness from a 1992-1996 Prelude or certain Accord models (not sure which Accord...)
Andrew
onesikviet
Dec 8, 2003 06:12 PM
SMC Integra
Aug 20, 2003 12:54 PM
91_hatch_si
Jan 4, 2003 10:59 PM
ElectricBlue13
Aug 26, 2001 07:48 AM
