OBD II Code P0118 Help
I went to autozone and they did a free scan of the check engine light on my car and it came up with a code P0118 and it was "Engine Coolant Temperature Circuit High Input". Has anyone have this problem before? I could really use some help with it.
Setup:
IN MY SIGNATURE
Setup:
IN MY SIGNATURE
according to your stock sensor in the dash is your car starting to over heat when it throws the code, if the stock sensor sees a normal temp, try replacing the coolant temp sensor.
eg9d16turbo
Sep 7, 2011 04:24 PM
deercanbrack
May 14, 2008 03:49 PM
