nos plate kit??
No, but that's what I plan on getting once I get some cash flow again
The ignition is underway, very soon. What were you wanting to know about it? I've read some on it and I know it's applicable for B18 (GSR) and H22 motors because the plate is specially designed for the intake manifolds. Not quite like a DP kit, but similar I guess you'd say. Depending on how built your motor is, that particular kit is adjustable 75-200 shot. That's a
in my book
[Modified by typeSwarrior, 12:47 AM 11/2/2002]
in my book
planning to use it on a stock 94 jdm h22....but in the NOS catalog is lists only for the h22a4's?? so wondering if it is compatible with the older h22 motors??? so its not like a Direct port system??
ya it says that but i was told the butterflies are the same for h22a1,h22a4,h23a1...someone also said the gsr ones are the same also? but i was wondering if they restrict airflow enough to lose hp? what about on a turbo motor?
The plate kit isn't coming out anytime soon unless you you have a direct hook up to Holley. The NOzles kit did come out though along with the import adapter for the injectors. Of course it is $1k+, but it's the easiest install that you they have.
