no spark - need help quick
Old May 18, 2005 | 02:56 PM
MadCityLude
Guest
Posts: n/a
Default no spark - need help quick
So I go to start my car after doing some work on it and it fires great. Let it run for 15-30 seconds everything seemed great. Then I go to start it later on and it starts to fire and dies.
Did all the checks I know of and I am getting fuel, BUT NO SPARK. Pulled the cap and cleaned the contacts on the cap, and replaced the rotor. (it was older. I replaced the cap about 5k ago.) But still nothing.
What should I do next??
Please help.
Thank you
Derek
Old May 18, 2005 | 03:17 PM
prelittlelude's Avatar
Default Re: no spark - need help quick (92_JDM_VTEC_lude)
are you sure your not getting a spark? you pulled the plug and layed the hex part on a grounded area and put the boot on he spark plug while having another person crank the engine?
what is the full setup of this car, no spark can be alot of things, what have you done modifications wise, when you say finished doing some work , what does that mean?
Old May 25, 2005 | 02:48 PM
MadCityLude
Guest
Posts: n/a
Default Re: no spark - need help quick (prelittlelude)
yes I grounded the end of the plug and have no spark!
I am running a JDM H22 stock except my intake basically.
The work I did was replace the TPS and radiator. Radiator cracked and blew radiator fluid all over. The car started after I did this stuff.
It was later in the day that it didn't start.
Please help anyone my car is stranded.
Thank you
Old May 25, 2005 | 06:54 PM
951dc5's Avatar
did you check the coil see if there's spark from there? Coil is what spark first. Let us know on your result
Old May 25, 2005 | 06:57 PM
98vtec's Avatar
moderator emeritus
Default Re: no spark - need help quick (Prelude951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">did you check the coil see if there's spark from there? Coil is what spark first. Let us know on your result</TD></TR></TABLE>
i was thinking the same
Old May 25, 2005 | 07:04 PM
xbn83's Avatar
Also check ignitor!
Boosted96gsr
Jan 9, 2012 08:04 PM
95sirek4
Sep 2, 2011 07:35 PM
Whitehatch18
Jun 7, 2003 04:30 PM
QTKEG6
Jun 23, 2002 10:14 PM
