new engine installed, dies at idle
Old Aug 9, 2004 | 01:38 PM
accord03coupe's Avatar
Default please, i need help!!!!!!!!!!!!!!1
here is the problem, i have and vtec 95 prelude and and have had water ran into the engine and the engine is broke, i bought a new engine to replace it, it's also vtec h22a1, when i finish every thing, and turn on the engine, you know when you turn the engine on, the rpm at first it high then it go low right, that it the problem when the rpm go low, the engine turn off and i couldn't drive like that, if i want to drive i have to keep the foot on the gas paddle all the time which i could do but it too dangerous, i really need your suggestion
thank
Old Aug 9, 2004 | 01:39 PM
Behan's Avatar
Default Re: please, i need help!!!!!!!!!!!!!!1 (accord03coupe)
possibly a vacumm leak, check your vacumm lines.
and for god's sake try to post in english.
Old Aug 9, 2004 | 02:01 PM
TxTuner
Guest
Posts: n/a
Default Re: please, i need help!!!!!!!!!!!!!!1 (Behan)
I'll second that on the english thing!!
Old Aug 9, 2004 | 02:02 PM
satan_srv's Avatar
Default Re: please, i need help!!!!!!!!!!!!!!1 (TxTuner)
did you do a compression test before you bought the engine? You coul;d have bent vavles in there...
Old Aug 9, 2004 | 02:12 PM
Behan's Avatar
Default Re: please, i need help!!!!!!!!!!!!!!1 (satan_srv)
after re-reading that for the 4th time, i think i understand it ( should i be scared ).
Forget the vacumm line idea.
Old Aug 9, 2004 | 02:18 PM
pentaq's Avatar
I could understand such an English as it's not my native language
Did you adjust your valves? Cleaning IAC also helps.
WojtekG
Sep 13, 2018 07:15 AM
dh1212
Apr 2, 2016 04:08 AM
ludesrv
13
Apr 13, 2007 08:29 AM
