msd coil question
Old May 26, 2010 | 01:33 AM
redlinez_r_us's Avatar
Icon2 msd coil question
i was wondering if i need to re-wire some thing if i change the stock external coil to an MSD external coil...i did not purchase any thing else but the external coil...meaning i don't have an MSD ignition box...need help...
Old May 26, 2010 | 08:04 AM
Apex1972's Avatar
Default Re: <~~MSD COIL QUESTION~~>
why do you need an msd coil? I read that its not good for the stock ignitor to run an aftermarket coil without the ignition box installed too.
Old May 26, 2010 | 05:51 PM
gstrudler's Avatar
Depends on which coil.
The only rewiring is to take the two positive lines (yellow & yellow/black iirc) to the positive side and the negative to the negative side.
Old May 26, 2010 | 06:03 PM
AyOhOndA's Avatar
I have the MSD Blaster 2 Coil Pack on a stock Cap and everything else stock, runs just fine. Well, I also have the bigger MSD PLug Wires too. On the stock external coil like gst said there are 4 wires running to the coil. On mine, we just connected the 2 positive and 2 negative and ran a single wire out to the +/- on the Coil. But running them like GST said works just the same. Just less wires if you connect them and run just 2 (+ n -) instead of running 4 wires across to wherever you mount the Coil.
Old May 26, 2010 | 08:43 PM
kornkid21792's Avatar
hmm i think i might do this so literally all u do is take negative and positive out of the plug for the existing external coil and plug it into the new one
Old May 26, 2010 | 08:51 PM
Mr.Ferio's Avatar
Default Re: MSD COIL QUESTION
ive had nothing but bad luck with the msd coil.... the stock coil NEVER gave me any problems so i stick to them...
Old May 26, 2010 | 09:03 PM
AyOhOndA's Avatar
Default Re: msd coil question
My Blaster 2 Coil has never given me a problem either. Make sure you're setting the wires right. And dnt use the positive on the Coil pack to hook ANYTHING else up. Fog lights, Underglow, LEDs, etc. It WILL drain your battery til it's dead. Made that mistake with my fog lights and killed my battery a few times b4 I realized. OH. DUH. lol. Cuz as long as the Coil Pack is grounded it will drain power from whatever is touching it, and in turn, drain your battery power.
Old May 27, 2010 | 01:49 AM
i was wondering if you can send me a pic of what your talking about...sorry kind of new to this things...don't want to mess any thing up...AyOhOndA...
Old May 27, 2010 | 05:29 PM
AyOhOndA's Avatar
Here's a picture of my MSD Coil Pack.
Where my finger is is the 2 wires coming off the wiring harness from the motor to the +/- on the Coil.
I took another picture, but my phone cant send it cuz the picture is big.
The 4 wires come off of the same Harness that go to your Distributor.
There's 4 wires coming off of the harness in the plastic wrap or electrical tape most likely.
Ok. Edit. On MY car there are only 3 wires. A black wire with a yellow stripe. A Yellow Wire, and a Blue wire. The blue wire is much skinnier than the other 2. The other two are the same size. The Black and yellow wire, and the yellow wire are spliced together. I'm guessing they are the ground but I am not completely sure. I'm gonna look at my wiring diagrams and see if I can find it.
Old May 28, 2010 | 03:04 AM
MikeLuder's Avatar
DO NOT DO THIS. YOU WILL EVENTUALLY BURN OUT YOUR IGNITOR IN DISTRIBUTOR.
Bet me, Paypal.
Old May 28, 2010 | 12:05 PM
gstrudler's Avatar
Yellow and Blk/Ylw are positive, blue is the negative. I have been running my MSD HVC coil like this for several years now without any problems (yes, I know, this is the wrong coil to use stock, I had a Digi6 that I was using with it that died).
Rodzknight
Jul 3, 2006 01:02 PM
951dc5
Nov 29, 2004 10:57 PM
juicedh22
Oct 9, 2004 05:45 AM
B_1_8_hatch
Nov 28, 2003 08:28 PM
GTEater
Jun 25, 2001 01:01 PM
