Map sensor wiring
Old Apr 4, 2009 | 08:46 PM
Kahuna9889's Avatar
Default Map sensor wiring
I bought a 3 bar map sensor and im not sure which wires are which. Does anybody know which wire is power and ground. I know the middle wire is the signal wire. Of the other 2 wires, one is green with a red strip and the other is red with a green strip. I cant find my voltmeter so i can test each wire.
Old Apr 4, 2009 | 10:50 PM
motoxxxman's Avatar
Default Re: Map sensor wiring
its a 5g lude by the way. i've been talking to him on AIM helping him rewire his ecu plugs after removing an aem fic that was hardwired in. and i completely forget which wire is which on the stock map sensor's plug
Old Apr 5, 2009 | 06:23 AM
Acidcrakker's Avatar
There are 2 other wires correct. One is white Blue, and the other is Blue White, right?
Thats for OBD1
Your OBD2
Red Green is map detect wire D3
I can tell you that much from looking here
Old Apr 5, 2009 | 08:37 AM
motoxxxman's Avatar
Thats for OBD1
Your OBD2
the wire colors at the map sensor are different than the wire colors at the ecu.
and the wire colors at the ecu are not always the same between all hondas
Old Apr 5, 2009 | 05:57 PM
The AW Alchemist's Avatar
Interesting. Ive found all my wire colors on OBD 1 to be the same so far.
WannaHonda
Aug 5, 2004 01:22 PM
flip1199
Dec 28, 2003 11:12 PM
flip1199
Dec 28, 2003 05:55 PM
ProjectLudeSiR
Nov 9, 2003 10:03 PM
xXx Justin xXx
Jun 18, 2003 09:49 AM
