Map sensor question, 99 prelude...
... Keep getting low voltage map sensor code... The only thing that I thought I could do was to change out the map sensor. Put on pgm testor and reading was 15.3... Thanks in advance for any help.
Just a few of the mods I have done... JG head with Skunk stage 2 cams, V-afc, cai, ignition, exhaust, headers
Did you mess with the knock sensor at all? It could be possible you have the wrong plug on your map sensor. My buddy with a 2nd gen b16a kept throwing the map code as well and it turned out the knock wire (if i remember correctly) was plugged into the map sensor and vice versa.
Did you put all this stuff on at once and then start throwing the code?
Yes I did put all the stuff on all at once.... If I did happen to hook it up backwards, would it be a sporadic problem? (Light comes on like once every two weeks and cars starts idling at a low rpm)
