MAF sensor or equivalent?
Old Feb 20, 2012 | 10:51 AM
balbowskie's Avatar
Icon2 MAF sensor or equivalent?
I got a 1993 Honda prelude si with a h23a1 engine. I was wondering because I don't think I have a MAF sensor, is there something else Honda uses that is the equivalent of the MAF sensor that some cars have or am i just overlooking something and I do have one?
Old Feb 20, 2012 | 10:59 AM
q16racer's Avatar
Default Re: MAF sensor or equivalent?
MAP - manifold absolute pressure.
Just fyi, most vehicle nowadays that use a maf also have a map sensor.
Old Feb 20, 2012 | 11:00 AM
97ludedude's Avatar
Your car does not have a mass air flow sensor. It uses the map sensor along with the throttle position sensor and intake air temp sensor to tell how much air it is breathing in.
Old Feb 20, 2012 | 11:12 AM
q16racer's Avatar
Kinda. but good enough lol.
The intake and coolant temp sensors are simply fuel corrections solely based on temp on top of regular base fueling. These are active in both maf and map based systems.
Old Feb 20, 2012 | 12:12 PM
balbowskie's Avatar
Wow, I thought some cars have both map and maf, but not in my case since now that I do know I am not using any maf. Anyone know if the operating voltage range of the map sensor is?
Old Feb 20, 2012 | 02:06 PM
97ludedude's Avatar
. . .i thought the ecu uses the air intake temp sensor to tell calculate how dense the air is so it can get enrichen it or lean the mixture. So to calculate air density like a maf does it does require the iat. ect sensor just tells the ecu when it can stop riching up the mixture when the engine reaches operating temp. a maf automatically tells how dense the air is no calculations required by the ecu am i incorrect on this?
Old Feb 20, 2012 | 03:23 PM
q16racer's Avatar
do some research on speed density and I think you will understand better. Temp sensors are just that, temp sensors. They do not sense any loads, thats what the maf and/or map is for. The throttle sensor is juat another sensor to tell the ecu what the driver is wanting to do.
iat and ect are simply corrections made by the computer based on what temp they are reading. When its cold outside and the motor is.cold it will increase cranking fuel because cold fuel and cold motors are tougher to start and vice versa....hotter climates and engines at operating temp take less fuel to start. as you drive and reach differrent coolant temp windows, the fuel correction amount drops.
Just read on speed density, it will help.
Old Feb 21, 2012 | 07:10 AM
balbowskie's Avatar
Hugh help! thanks alot!!!! I see how this is working now!! I'm going to see what else I can dig up on speed density.
iwantspeed
Honda Civic (2001 - 2005)
11
Jan 5, 2007 07:20 PM
RACEPAK
Jul 30, 2004 09:34 AM
Layziebtnh055
Apr 14, 2004 07:58 AM
Shiftpointshaun
Apr 2, 2004 07:58 PM
ramz7887
Nov 1, 2003 08:43 AM
