looking at a prelude. help!!!
Old Dec 18, 2008 | 10:24 PM
cramos1222's Avatar
Default looking at a prelude. help!!!
hey im looking to buy a '98 prelude type sh manual. just want to know the common problems. i tried looking for a thread with some info couldnt find any. so a link or a little advice would be great! thanks.
Old Dec 19, 2008 | 02:47 PM
kingh90's Avatar
post a pic and whats the price?
Old Dec 19, 2008 | 02:50 PM
Kronn 98SH's Avatar
Most common problem for the Prelude SH is bad drivers. If you aren't one and you avoid those who are, you're golden.
Old Dec 19, 2008 | 02:52 PM
HondaGuy951's Avatar
the biggest problem with an H22 is the timing belt tensioner....it tends to move, but if it's never had a prob. with it. ur coo
Old Dec 21, 2008 | 09:12 PM
303h22's Avatar
Default Re: looking at a prelude. help!!!
some of the timing belt tensioners got replaced though in a service bulletin through honda dealers not a recal just a bulletin. but some problems are use of oil always check the oil.
Old Dec 22, 2008 | 03:01 PM
honda_prelude_jay's Avatar
If the car has over 100k on it would be nice to see papers showin that the timing belt and tensioner have been replaced. The tensioner leaks oil and then the timing belt flapps against the case and eventually shreds the belt or skips a tooth.
Womp the engine from idle to just about 1,500 and back down a few times. Listen around 1000-1200. If the tensioner is shot, at that rpm range you can hear a slapping/rattle, especially if your head is under the hood. You can put your hand on the timing cover case and feel it slapping.
Always look UNDER the car. the undercarrage can be a great indicator of what kinda life the car has had
Old Dec 23, 2008 | 12:47 PM
Drive it and make sure it shifts smooth and dosn't grind syncros
Old Dec 23, 2008 | 03:40 PM
gstrudler's Avatar
i'd ask to see whatever service records they have and what TSB's have been done; the oil seal retainer was a pretty important one. doing a compression & leakdown test is always a good idea as it will give you a general indication of the motor. any mods done to it?
Old Dec 23, 2008 | 03:57 PM
LobeSex's Avatar
get a 4th gen
emt-fire_lude
Jun 21, 2005 06:43 PM
rossockr
Feb 20, 2003 03:29 PM
79 civic
Dec 1, 2002 07:12 AM
