Kteller Resonator
Old Jan 27, 2006 | 12:27 AM
snowblind7x's Avatar
Default Kteller Resonator
I'm getting a custon 2.5 inch exhaust with a hi flow cat and a magnaflow muffler. I've heard that even with a high flow cat the magnaflow can still be a little raspy. Should i just go ahead and pick up a kteller resonator here http://www.kteller.com/store/p...d/713 to lower the tone a bit more? Or are there any better resonators someone wants to suggest? And the resonator on kteller is 18 inches, is that ok?
Old Jan 27, 2006 | 12:37 AM
hu's Avatar
hu
Default Re: Kteller Resonator (snowblind7x)
Which hi flo cat are you going with?
https://honda-tech.com/zerothread?id=1323923
https://honda-tech.com/zerothread?id=1115623
A resonator should cure the problem to a degree, but I am not sure how much.
Old Jan 27, 2006 | 12:38 AM
Default Re: Kteller Resonator (hu)
magnaflow carsound high flow cat
Old Jan 27, 2006 | 12:45 AM
hu's Avatar
hu
Take a look at the first post. There are some higher flowing cats. SMSP did some testing. You might change your mind, you might not.
Old Jan 27, 2006 | 12:47 AM
yeah, i just saw that but i already have the high flow cat, i would just need to get a resonator now.
Old Jan 27, 2006 | 01:24 PM
oh, and I can get the resonator 14", 18", or 22" inches long for the same price. Which size should i get? What's the difference?
Old Jan 27, 2006 | 01:50 PM
98TypeSH's Avatar
the longer the resonator the more it will quiet the exhuast.
I had a 18" on my JUN head with no cat and it wasnt raspy. 18" should be fine. If you want to make damn sure, get the 22".
Old Jan 27, 2006 | 01:54 PM
MilanoLude's Avatar
Default Re: Kteller Resonator (98TypeSH)
You should measure the distance from your cat to the closest bend, you need to make sure there's enough straight length of piping before the bend in your exhaust. 22" might be too long, you also have to consider there's a hanger about 1/4 of the way from my stock cat to the next bend, guess that doesn't make much of a difference, but it'd mean more work because youd have to weld a hanger onto the resonator if it gets in the way.
jdmhatch1
20
Jan 5, 2008 05:14 PM
00siandrew
May 11, 2006 05:09 PM
BDogggUT34
Feb 8, 2005 11:08 AM
zcivicz
30
May 14, 2002 07:19 AM
