Key chime
Old Oct 25, 2017 | 02:06 PM
underknown's Avatar
Default Key chime
it will not shut up 98 prelude even with the key out and lights off if the door is open it is beeping. Please help before I superglue the door switch thanks in advance.
Old Oct 25, 2017 | 02:35 PM
1992BB2's Avatar
Default Re: ******* key chime
I would assume its the ignition switch. The switch probably thinks that the key is still in the slot. It may be repairable without replacing the ignition switch. Check the helms.
Old Oct 25, 2017 | 04:07 PM
underknown's Avatar
Default Re: Key chime
New ignition switch cylinder clicks when key is taken out
Old Oct 26, 2017 | 07:54 AM
underknown's Avatar
Blown headlight bulb had it tripped out. R&R high beam bulb and it fixed itself.
Old Oct 28, 2017 | 09:40 PM
1992BB2's Avatar
Interesting. Glad to hear you figured it out!
fazalabbas
Jan 5, 2019 10:36 PM
wasp9166
Sep 25, 2013 07:40 AM
Civic Racer X 7
Feb 25, 2011 12:31 PM
benmyfriend
Dec 4, 2005 09:54 PM
