JDM auto vtec
Old May 27, 2012 | 05:06 PM
daveypower's Avatar
Default JDM auto vtec
hey lads just wondering is the automatic gearbox JDM DOHC Vtec engine, the same bhp as the manual version, as the add ive read says its 160bhp? i thought it was still 200bhp? thanks.
Old May 28, 2012 | 04:42 AM
daveypower's Avatar
Default Re: JDM auto vtec
bumpy bump bum bu b
Old May 28, 2012 | 07:21 AM
snobordboy's Avatar
Moderator
Not sure where that rumour got started, maybe just since the auto doesn't put as much power to the ground, since it is less effecient than the manual trans?
In any case they are the same compression, same cams etc. so the engine makes the same power.
Old Jun 5, 2012 | 01:54 PM
99jdmh22prelude's Avatar
ECU's are tuned for 10hp less than their manual counter parts.
that is all.
Old Jun 6, 2012 | 03:38 AM
TRIO's Avatar
the only engines ever rated anything lower then 200 hp or so was: H22A5 182hp ,H22A2 182hp ,H22A1 (vti-r Australia) 182hp, h22a1 USDM 187 hp
as far as manual or auto is the same thing the engine does what it does power wise, now gear ratio bla bla bla 0-60 time 1/4 time bla bla is a different story.
the only time i ever seen a h22 do 160 is a h22a1 usdm but it was 160-165 whp so yea.
Old Jun 6, 2012 | 03:43 AM
TRIO's Avatar
o yea before i forget JDM h22a is actually 197 hp @ 6,800 rpm and type S is 217hp @ 7,200 RPM factory claims.
Old Jun 21, 2012 | 05:17 AM
daveypower's Avatar
So if i bought an auto one, threw my manual 5speed into it, and the ecu, it should be putting out 200bhp. ( i know it wont be 200bhp now)
Old Jun 24, 2012 | 06:26 PM
BB1 H22A LUDE's Avatar
Yes, JDM H22A's, whether mated to an auto or manual transmission are rated with the same flywheel hp (200ps/197hp) and torque (218.7nm/161.3lbf·ft).
Key difference engine wise will be the throttle body blade having extra holes for the trany cable, but makes no difference for a manual. May also be flywheel differences and engine mount differences but I am unsure of that. Also, there is about a second difference between the two down the 1/4 mile (varies but ~15.2+/-0.4sec for a manual and ~16.2+/-0.4sec for an auto).
Old Jun 24, 2012 | 07:21 PM
horsepowerless's Avatar
BHP is not wheel horsepower, its HP at the crank. the Si has 160hp at the crank, and it is also not a VTEC motor...
Dr. Willy
Apr 7, 2008 09:43 AM
vietherbs
Sep 9, 2007 08:38 PM
THC07
Dec 12, 2006 01:15 PM
pierreram
Acura TL, RL & ZDX
Aug 8, 2003 10:21 PM
CrxSi10
Jan 15, 2002 09:51 AM
