intake manifold?
Old Oct 21, 2003 | 04:59 PM
tea's Avatar
tea
Default intake manifold?
What is the saucer like object on intake manifold on the driver's side? Also there is a vacuum hose hooked up to it, but I found mine dangling and unhooked, and I was wondering where it attaches to? Thanks for the help.
Old Oct 21, 2003 | 06:25 PM
junbb1's Avatar
Default Re: intake manifold? (tea)
the vacum line goes to the port coming off your "saucer thing" - diaphraham. it is for your intake butterflies. hook it up and you will have more bottom end power.
Old Oct 21, 2003 | 07:31 PM
tea's Avatar
tea
Default Re: intake manifold? (junbb1)
The vacuum hose hooks up to the saucer and where does the other end go?
Old Oct 22, 2003 | 04:50 AM
19924ws's Avatar
To the black box on the under side of the intake.
Old Oct 22, 2003 | 05:17 AM
Jagan'92's Avatar
Default Re: (19924ws)
And if the intake is replaced with aftermarket? Cap it off, verdad?
Old Oct 22, 2003 | 06:38 AM
Sephro's Avatar
Default Re: (Jagan'92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jagan'92 &raquo;</TD></TR><TR><TD CLASS="quote">And if the intake is replaced with aftermarket? Cap it off, verdad?</TD></TR></TABLE>
what? If you have an aftermarket intake Manifold you shouldn't have that. Unless there is an aftermarket manifold with butterflies???
Old Oct 22, 2003 | 07:13 AM
Jagan'92's Avatar
Default Re: (Sephro)
I thought he was talking about the hose which runs from the intake manifold to the resonator box? He says saucer thing - I know there's one valve on each end. Guess I'm lost.
If that saucer on the driver's side of the intake manifold is capped off - i.e. it doesn't run to the resonator box (because there is no resonator box), what happens?
Old Oct 22, 2003 | 09:16 AM
Sephro's Avatar
I'm not 100% what your asking here. Is the thing that you are referring to the thing that is being pointed to in this pic I stole from another thread here.
Is that the saucer thing your talking about?? Sorry it's kidna hard to see in that pic.
Old Oct 24, 2003 | 05:01 AM
Jagan'92's Avatar
Ah, i'm not sure what i was talking about - or what he was asking. Guess he won't clarify it, oh well.
I'll ask a question then. There is a valve on the resonator box of the air intake with a vacuum hose which runs to the intake manifold (maybe the throttle body actually).
So when the resonator box is pulled, and that valve is removed - I fished that vacuum hose back to the manifold (or TB) and capped it off. Question is - should I leave it open. I assumed it was vacuum, so cap it.
thunderboy
Jul 19, 2008 06:10 PM
RNbuilt
Nov 10, 2007 07:44 PM
silentdaredevil2
Jan 3, 2006 03:14 PM
Car_Addict
Nov 10, 2002 07:42 PM
