Intake Manifold
Old Jan 1, 2002 | 04:36 PM
The Punisher's Avatar
Default Intake Manifold
Ok guys, check this out. I am going to get my intake manifold ported and polished to match my head. Can I get rid of the butterflies, or will it bog my sh*t too much at the lower end? I thought since the STR is pretty much just a straight shot, that this would be about the same thing. Let me know because I am doing this REAL soon.
Old Jan 1, 2002 | 05:15 PM
boomslang's Avatar
Default Re: Intake Manifold (gsr*lude)
I'd keep them.
Old Jan 1, 2002 | 06:03 PM
akkording's Avatar
New User
What is the primary function of the butterfly? Will it give a CEL if you remove it? I might do this mod also.
Old Jan 1, 2002 | 07:26 PM
laughinxxx's Avatar
New User
Default Re: Intake Manifold (akkording)
The butterfly valves control the air flow into the engine. At low rpms they are closed, so less air gets in, and vice versa at high rpms. I don't think you'd get a CEL.
Old Jan 1, 2002 | 08:54 PM
nicksweetlude's Avatar
Default Re: Intake Manifold (laughin2.2)
im pretty sure you wont get a CEL. but i wired my butterflies open one time and it made no difference if anything i lost some bottom end. they open at 4800 rpm if im not mistaken. but i would leave them alone
Old Jan 1, 2002 | 11:18 PM
Greyout's Avatar
Default Re: Intake Manifold (nicksweetlude)
I made mine stay open all the time and it sucked. I got less then 240 miles per tank of gas, and when I put it back to stock I noticed that it felt much healthier down on the bottom end.
Old Jan 2, 2002 | 08:43 AM
H22Si's Avatar
The IAB Butterflies help build torque down low. They then open when when more air is required (4,800). Unless your "need" more airflow, like with a turbocharger, i'd leave it alone.
Default Re: Intake Manifold (JDM LUDE)
JDM, were you running N/A or FI. I am going to be running a FI setup. Will it put too much air at the bottom end, or can I tune around it with a Hondata?
This is thing that is getting me. How is it that the STR, Golden Eagle, and other intakes differ? Has anyone here used that type of intake manifold?
This is what I think, I am no expert, but if you are running a turbo setup, and the whole goal is to get as much air, as quick as the intake manifold will let in, wouldn't that be a good thing? Wouldn't the butterflies opening when the VTEC engages, screw with the tuning? I guess SgT had better get in on this one!
Help me out guys!
Old Jan 2, 2002 | 08:55 AM
Big James's Avatar
New User
If you are going FI, this would help out. However, on an NA car, it will lose bottom end.
Old Jan 2, 2002 | 02:08 PM
Greyout's Avatar
if you are going FI, then do it for sure! those butterflies will never open under boost!
Old Jan 2, 2002 | 06:52 PM
Well, I am almost sold, I am looking a little bit further into it, keep the posts coming!
Old Jan 3, 2002 | 06:15 AM
H22Si's Avatar
Just though i'd add; Before aftermarket intake manifolds became available, it was a common practice to remove the IAB butterflies on GSRs for more flow (high RPM). But if the added airflow is not needed, it should hurt performance.
Old Jan 4, 2002 | 07:22 AM
clendaniel's Avatar
you won't be able to tune the opening using the hondata...it's supported on the P72 ecu but you can't modify the actuation point. You could substitute a MSD rpm switch and use it to trigger at whatever rpm you choose.
As to them not opening under boost...I don't believe that's the case, in fact I think it's the opposite. Someone that's had them off recently should be able to confirm or deny but IIRC vacuum holds the butterflies _closed_. If I'm not mistaken this would mean that when you transition to boost they'd open automatically as there is no longer a sufficient vacuum in the intake to hold them closed. This should be an ideal situation as it maintains the "factory" funtionality when off boost but then aids in flow once pressures are raised above atmospheric.
Of course I could be wrong and just talking out my ***...
--Ian
Sparkles
89
Apr 6, 2008 02:04 PM
menkio
Jul 24, 2004 03:01 PM
CRXSi90
May 12, 2003 05:23 AM
tylerdurden
Jan 30, 2003 05:46 PM
four27
Dec 13, 2002 07:06 AM
