Installing CamGear : Quick Question
Gonna be putting on some camgears this weekend and i just want to make sure that i will be able to loosen / torque down the cam gear bolt with out having the cam gear rotate. Does it need to be held from rotating like the crankshaft pulley? If so, what are some methods i can use.
Hmmm, the reason i ask is because it doesnt state anything in my helms about holding the camgears from rotating, but its only right that they will move when you go to tighten them. Can anyone confirm that you need or not need to hold the camshafts in place while removing/installing the gears?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fly1865 »</TD></TR><TR><TD CLASS="quote">There are keys that hold the Cam gear in line with the Cam-shaft
#37
I know about those, what im saying is that when i go to re-install the gears i have to torque them down to 37ftlbs. Now, if the gears rotate as im trying to tighten them, i wont be able to acomplish this. Much like the crankshaft pulley. It has to be held from rotating in order to torque. Or will 37ftlbs not be enought torque to rotate the whole timming assembly (Crank, and gears), i should be fine if that is the case.
#37
</TD></TR></TABLE>I know about those, what im saying is that when i go to re-install the gears i have to torque them down to 37ftlbs. Now, if the gears rotate as im trying to tighten them, i wont be able to acomplish this. Much like the crankshaft pulley. It has to be held from rotating in order to torque. Or will 37ftlbs not be enought torque to rotate the whole timming assembly (Crank, and gears), i should be fine if that is the case.
I don't know if you know this or not, put there are 5mm holes, one above each cam, on the cam holders, next to the cam gears. You can put a 5mm anything, allen wrench is pretty good, in the hole, and that will help hold the cam still....make sure it goes through the hole in the cam, though...
drumminforev
Oct 19, 2006 06:28 PM
agent marlon
Nov 21, 2002 11:49 AM
