Install help???
Old Oct 16, 2002 | 06:57 AM
LuderX's Avatar
Default Install help???
Can anyone point me to a site that would show me how to install a intake??? Also i want to know is it something that a noobie like me can do??
Old Oct 16, 2002 | 07:04 AM
prelude1897's Avatar
Default Re: Install help??? (LuderX)
go to http://www.ntpog.org
[Modified by prelude1897, 10:05 AM 10/16/2002]
Old Oct 16, 2002 | 10:43 AM
armharm's Avatar
it should be pretty easy if ur the handy type...
Old Oct 16, 2002 | 11:10 AM
DSGB.'s Avatar
Dirty Bird
Default Re: Install help??? (armharm)
Its very easy, You should have no problem installing it.
Old Oct 16, 2002 | 11:55 AM
ajabbar's Avatar
Default Re: Install help??? (Blurple92si)
It's basically like this! Take off the intake box clear everything out watch out label anything you unplugged then...put the intake where the box use to be and it should be designed to fit it, plug anything you took apart and you should be set!!
Old Oct 16, 2002 | 01:31 PM
RAB's Avatar
RAB
this is what I used. very good install instructions.
http://www.lightningmotorsports.com/...ai_install.htm
Old Oct 18, 2002 | 05:26 AM
LuderX's Avatar
thanks for everything. I finished installing it. but should the intake shake alot when i rev my engine? because the intake is not bolt down onto the body would it do any damage to the intake?
Ph0t0bug
Dec 30, 2015 09:26 PM
dinozsn
Jul 14, 2005 02:37 PM
