Indicators of a rich engine....
Old May 16, 2003 | 12:08 PM
dvp95's Avatar
Default Indicators of a rich engine....
I was just wondering if there were things that could tell you if your engine is rich or not besides the spark plugs. I have a 98 jdm h22 in a 96 accord. I will by setting up my direct port soon and just want to make sure everything is ok. My spark plugs are sort of this green/light gray color. If you look at my muffler and in the exhaust ports, it is a black color. Am I running lean or rich? Thanks
Old May 16, 2003 | 12:17 PM
Greyout's Avatar
Default Re: Indicators of a rich engine.... (dvp95)
I've poured way too much money into my car for it to be anything but rich
HAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
ahem - anyway, your plugs should be a light brown, dark grey-like color.
edit: what fuel pump are you using
Old May 16, 2003 | 12:20 PM
743's Avatar
743
Default Re: Indicators of a rich engine.... (JDM LUDE)
the first dead giveaway for your car running rich is the fact that its a Honda. Honda's run rich, simple as that, sounds like your fine.
Old May 16, 2003 | 12:26 PM
Greyout's Avatar
Default Re: Indicators of a rich engine.... (-743-)
just assuming everything is ok is the first step to having your engine laying in pieces in the garage.
give us more info on your setup - mods, fuel and fuel system... accord pump?
Shakes's Avatar
space cadet
what are the indication on the plugs of it is running rich? i know white is lean.
Old May 16, 2003 | 12:28 PM
743's Avatar
743
Default Re: Indicators of a rich engine.... (shakes)
if they look like someone took a **** on them and smothered them in dirty oil...your runnnig rich.
Old May 16, 2003 | 12:30 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -743- &raquo;</TD></TR><TR><TD CLASS="quote">if they look like someone took a **** on them and smothered them in dirty oil...your runnnig rich.</TD></TR></TABLE>
lol, nice thanks. i understand what you are saying dont get me wrong... but is what you are describing the same thing as fried plugs from spraying?
Old May 16, 2003 | 12:46 PM
Greyout's Avatar
if they are oily, thats usually not a great sign
Old May 16, 2003 | 03:41 PM
dvp95's Avatar
My setup is pretty much stock including the accord fuel pump, msd digital 6+ and ss coil, then your basic i/h/e. I have a walbro 255 pump, b&m guage and fuel modifier waiting to go in. Thanks for your input.
Old May 16, 2003 | 07:43 PM
dvp95's Avatar
Here are the results from my last emissions test that was about 2 weeks ago.
HC- .0969...limit 1.2
CO- 2.4238...limit 20.0
NOx- .2520...limit 3.0
It says on the bottom that a high CO reading means that it is running rich. So how do you interpret my numbers? What does a CO reading of 0.0 mean?
Modified by dvp95 at 6:49 AM 5/17/2003
Old May 16, 2003 | 07:47 PM
sslude's Avatar
drive with a friend behind you, and floor it, ask your friend if he saw black smoke come out. i once saw a thread wtih a picture of exhaust all over his garage door, running rich
Old May 16, 2003 | 08:25 PM
del_parker's Avatar
Default Re: Indicators of a rich engine.... (sslude)
i've had one flame come out of my exhaust... fnf
Art Vandeleigh
Mar 29, 2005 10:34 PM
tea
Sep 26, 2003 07:09 PM
Loveless
Apr 2, 2003 03:17 PM
Nate B
Feb 10, 2003 08:26 PM
RJL
Oct 27, 2001 11:44 AM
