ignition coil test
my car hasnt been starting and i tested for spark and i didnt have spark so im testing the ignition coil. it has power and the resistance from the primary connector to the secondary connector is within specifications but the resistance between the two terminals in the primary connector is 1 ohm when it should be between .6-.8 ohms. my question is, is 1 ohm really too much? my guess is since the range is only .2ohm being .2 over the max isnt good but the difference still seems small so i wanted to check.
